TPI swap? How much lighter will my wallet be and how hard is it going from tbi?
Old Sep 26, 2006 | 09:09 PM
Blazin4x4's Avatar
Car: 1988 Chevy silverado K5
Engine: 350 bored .030, crane cams hyd bluprint l-79 cam 447 lift 272 dur, camel hump heads port and polished 1.94 1.50, afterburner headers and y pipe, holley 670 cfm tbi, holley projection dual plane manifold, accel high pressure fuel pump, 3 inch exhaust
Transmission: 700 r4 with corvette servo and shift kit.
How much would a tpi swap run me assuming I could get it from a junkyard? What all would I need?
Is it difficult?
Is the tuning easier then the tbi computers?
Old Sep 26, 2006 | 10:57 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Tuning is tuning, doesnt matter what ecm, some have more variables , other than that its time.
The cost involved will simply depend on how cheap and how complete a setup that you buy in the first place for the conversion.
If you shop, you should be able to get an intake with sensors/ecm/harness for $300 or so.
If u do that, you have everythign u need.
Several writeups here on it, rather simple conversion. Hardest part will be finding the wires you will need to splice to make all your guages work in your application.
later
Jeremy
Old Sep 26, 2006 | 11:50 PM
Blazin4x4's Avatar
I know you probably won't know but is tpi cleaner then tbi? I have to stay with CA smog. It would be on an 88 chevy blazer with a 350 tbi motor.
Old Sep 27, 2006 | 02:49 PM
Guest
Guest
Posts: n/a
Putting a TPI under the hood of a Blazer enters the red tape area since they never came with TPI. You'd have to go to the referee, not something you really want to do.
I'd try to find a donor car if you're not real sure what you need, or you might get nickel and dimed to death. But the intake manifold up, including the harness, all sensors and relays, fuel pump, and the computer will be a minimum of what you need.
92camaroJoe
Jul 29, 2023 07:57 PM
db057
Aug 22, 2015 08:17 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Sanjay
Aug 12, 2015 03:41 PM
squiggy2
Aug 9, 2015 09:30 PM
