Motor dies when shifting to reverse & drive
Old Sep 26, 2006 | 07:33 PM
joejoe's Avatar
Car: red one
Engine: on the floor
Transmission: next to engine
Axle/Gears: the ones that turn
Just as I stated...motor dies when shifing to reverse or drive , but if you hit the gas just a little, and let off, it will idle fine in gear. EVERYTHING is new, except distribtor (sp?) all sensors, new motor & trans. injectors, all vacuum lines, EVERYTHING.....what could cause this problem? If more info is needed let me know.
joe
Old Sep 26, 2006 | 07:41 PM
fire350tpi's Avatar
Car: 1988 Pontiac trans am/gta
Axle/Gears: 3.23's
my buddy hasa 80's blazer he has the same problem, my shop teacher said it may be the distributor shaft, its a comon problem it has a leak etc
If u have the cap of see if theres any white residue.. then thats your problem
Old Sep 26, 2006 | 07:57 PM
joejoe's Avatar
Car: red one
I will pull it off and take a look,I will post my findings.
Old Sep 26, 2006 | 10:09 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
I would clean the throotle blades and remove the IAC and clean it. There is a specific method on how to prperly remove the IAC, clean it, and re-install it.
I think that the IAC is slow to respond when it needs to turn out & allow more air into the plenum.
Then do the IAC reset procedure and set minimum air, and set the timing.
Old Sep 26, 2006 | 10:36 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
I'll go with Doc on this one.
Sounds way to much like a TB cleaning and setting along with the IAC and TPS.
Follow the procedure here in the tech articles and then worry about chasing leaking distributors (sorry, had too)
later
Jeremy
Old Sep 27, 2006 | 05:24 PM
fire350tpi's Avatar
Axle/Gears: 3.23's
later
Jeremy
Sigh sorry i cant remeber specificly what he said, i believe the shaft leaks some residue when u put load on the engine, i wish i could remeber the specifics lol
Old Sep 27, 2006 | 07:57 PM
joejoe's Avatar
Car: red one
TB has been cleaned, IAC is new, distribtor has 165,000 so shaft is worn bad.
TPS is set at .55 volts.
My tach is not good enuff to set min. idle air (motor dies befour it get to 500RPMs) need better tach (fri.) and will set it again and see what happens.
thanks guys,
joe
jklein337
Sep 19, 2018 06:23 PM
Andrew6.688
Dec 13, 2015 10:59 AM
Streetstuff
Carburetors
Sep 7, 2015 02:33 PM
BewleyBizzIROC
Aug 14, 2015 02:52 AM
hokis
Aug 9, 2015 03:57 PM
