can i run ls2 injectors?
Old Sep 29, 2006 | 11:09 AM
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Transmission: Magnum F
Axle/Gears: TNT 8.8 wavetrac 3.31
ok i will make this simple i just bought a supercharger and im running 25lbs ls1 injectors now the ls2's are 36lbs but will they interchange?
Old Sep 29, 2006 | 12:08 PM
92droptopws6's Avatar
Car: '88 Trans Am
Engine: 5.7L TPI
Transmission: Slushbox
the injectors will interchange but will not be 36lbs with 44psi the Ls series injectors are rated at that 36lbs with 50+psi,personally i would buy a set of racetronix 36lb inj.(JMHO) racetronix - index
what psi are you running at the regulator now?
do you have a air/fuel guage or wideband?
if you are at 44psi with the 25lb inj. you actually are running no better than 22-23 lbs...
Old Sep 29, 2006 | 01:32 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I accually have my LS1 injectros constant set to 30. If I put 25 as the constant its pig rich through out the entire tuning time. Doesnt move off 108. With 30 its runs and drives 10's better and has a lot more power.
Old Sep 30, 2006 | 08:48 AM
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
when i got my car dyno tuned the guy set my fuel psi to 37lbs. nope no a/f ratio gauge yet
Jae992
Aug 27, 2015 09:07 AM
justin57
Aug 20, 2015 07:05 PM
ezobens
Aug 19, 2015 10:29 PM
tmellott89
Aug 16, 2015 02:58 PM
Thirim
Aug 13, 2015 03:09 PM
