Estimate HP/TQ numbers and compression???
Old Sep 29, 2006 | 11:23 AM
1987earthquake's Avatar
Car: 1987 Camaro Z28
Engine: 5.3L
Axle/Gears: 3.42LSD
Can you guys give me an estimate on my HP/TQ? Also what would my compression be.
Setup:
880 block (come out a 94 z71)
350 bored 0.030 over
Flat Top pistons with 4 valve relief
Stock rods and crank
high volume oil pump
Vortec heads bowl blended
260H flat tappet cam
Felpro blue head gasket.
TPI intake
Serpentine pulley set-up
roller rockers.
700r4 trans w/ 2500 stall
Old Sep 29, 2006 | 12:46 PM
Engine: 5.3L
Axle/Gears: 3.42LSD
bump
Old Sep 29, 2006 | 03:14 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
250ish to the wheels.
Old Sep 30, 2006 | 09:54 AM
V8Rumble's Avatar
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
Originally Posted by 1987earthquake
Setup:
Why the flat tappet in the '94 block?
Old Oct 1, 2006 | 01:24 AM
89Nighthawk's Avatar
Car: 89 GTA Nighthawk
Engine: 389 CID Vortec TPI
Transmission: TCI 700R4 w/Vigilante
I ran the numbers for you. But, your compression depends on where your pistons are installed, zero deck, in the hole? I believe your head gasket is .043 so assuming a 30 thousanths in the hole you get 9.7:1 CR.
296 HP 407 TQ assuming headers and a good exhaust. I probably shouldn't have done this, you didn't give enough information to be accurate, but it's close.
Old Oct 2, 2006 | 10:00 AM
Engine: 5.3L
Axle/Gears: 3.42LSD
All truck blocks came with flat tappet. What other info would you need to get more accurate numbers. Oh the pistons were installed at stock height. I didn't deck the block. I will have headers, no smog, no cat, flowmaster mufflers. Let me know what else info you would need. Thanks!
Old Oct 3, 2006 | 04:02 PM
Engine: 5.3L
Axle/Gears: 3.42LSD
bump
Old Oct 3, 2006 | 10:18 PM
299 HP 417 TQ. With stock installed height pistons and headers, no cat, flowmaster, etc. I was close the first time.
Linson
Oct 24, 2025 02:00 PM
LT1Formula
Oct 8, 2015 08:34 PM
bjpotter
Oct 4, 2015 07:48 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
3.8TransAM
Sep 27, 2015 08:37 PM
