I need Help Getting My TPI To Start
Old Oct 12, 2006 | 12:04 AM
babybear82's Avatar
Car: 1987 trans am
Engine: TPI 350
Axle/Gears: 342
I have a 1987 T/A TPI 350 Had It Since High School I tryied to buy pass the mas sensor and blew the ecm since ii had the new ecm put in the cars service engin light does not come on when the ignition is turned on and the engin must turn over at least 15 to 25 times before it will start and right before it starts the service engin light blinks and the vrooom it starts does any body have any suggestions as to what area i need to adress first
Old Oct 12, 2006 | 12:08 PM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
First things first, decrease your font size next time you post.
You don't want to bypass the MAF or MAP sensor, whichever you are referring to, that = bad.
Checking your timing is the first place I would start.
Old Oct 12, 2006 | 12:11 PM
ezysk's Avatar
Car: 1986 Firebird / 1985 Trans-Am
Engine: 305 4BBL / 383 4BBL++
Transmission: 700R4 / 700R4
Axle/Gears: ?.?? / 3.47
Are you getting any engine codes now?
Caspar
Jun 19, 2016 11:19 PM
Wade787b
Sep 29, 2015 01:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
L98GTA87
Aug 5, 2015 11:02 PM
