rusted return line
Old Oct 13, 2006 | 04:51 PM
redcamaro83's Avatar
Car: 86 Z28
Axle/Gears: TBD
rusted return line
car is an 86z currently running 305 tpi
what size is the stock return line
Old Oct 13, 2006 | 08:10 PM
Damon's Avatar
5/16". Main feed line is slightly larger- 3/8".
Old Oct 20, 2006 | 04:55 PM
Car: 86 Z28
Axle/Gears: TBD
thanx for the info now is that evap/tank vent line 3/16 (same as brake line)or ?
Old Oct 21, 2006 | 11:12 AM
Car: 86 Z28
Axle/Gears: TBD
ok officially here the sizes for any one replacing stock fuel lines from the tank rubber hoses forward, if its tpi you will probably have
Main fuel supply (largest line) 3/8in
Return line (second largest) 5/16
Tank vent- evap line 3/16
Rear brake line 3/16
these are the lines you should see under the car if you need to replace some
the brake line will be attached to a flexing typ of line at the front if u need to determine which is which.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
!CamaroDave
Members Camaros
Sep 5, 2015 10:39 AM
mrdevontay
Sep 2, 2015 08:04 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
