cold air intake help needed/87 irocz 350 tpi
Old Oct 15, 2006 | 07:38 PM
chevycamaroiroc's Avatar
Car: 87 Chevy Camaro Iroc-z
Engine: 350tpi
Axle/Gears: 3:27 POSI
Hey i need some help ,right now my iroc currently has the factory air filter setup with the dual filters and the plastic assembly,but am looking for a cold air intake kit that has chrome tubing to give th engine bay that nice look,ive seen a couple cars with chrome cold air intakes,help would be greatly appreciated thanks alot,and if anyone knows were i can get what am looking for links would also be appreciated thanks
Old Oct 15, 2006 | 07:44 PM
TPI383Camaro's Avatar
Car: 2008 Mazda B2300
Engine: 2.3l 4cyl
Transmission: 5-speed
well its not chrome, but SLP makes a cold air intake kit
http://store.summitracing.com/partdetail.asp?autofilter=1∂=SLE%2D21000&N=700+4294908216+4294908198+4294925008+4294840140+4294925239+4294813803+115&autoview=sku
if you want cold air and chrome... get a procharger and a intercooler
Old Oct 15, 2006 | 07:45 PM
subliminal's Avatar
Camaros dont need a colld air intake the stock one isnt that bad and it can be modified to flow really well.
Old Oct 16, 2006 | 02:31 AM
fin170703's Avatar
Car: '87 iroc camaro
Engine: 350 L98
Transmission: 700-R4
Axle/Gears: 3.27 posi
there is a post on modding a stock tpi air box on this TPI section
Old Oct 16, 2006 | 08:06 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
You can increase the stock flow by alot, but its not chrome.
For the engine bay, add some chrome parts to dress it up. For the air flow stuff, do the do-it-yourself ram air. Remove the air lid and the twin air filters. Look down in the square holes, remove the curved baffles that you see. Buy 4" dia ducting, and bring air up from where the fog lamps are. I removed the fog lamps from my IROCZ, and installed a similar ram air setup. I'm getting tons of air to run my 395 cu.in stroker. My setup is very effective.
Maybe you can paint the air lid for show.
1992 Trans Am
May 10, 2023 07:19 PM
wruiz
Aug 13, 2015 09:07 PM
Jake_92RS
Aug 11, 2015 10:39 AM
bryan623
Aug 10, 2015 11:33 AM
