calling any tpi guys with afpr
Old Oct 24, 2006 | 07:54 PM
91greenbird's Avatar
Car: 2012 Ram express
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
Im going to a local speed shop and im gonna pick up a holley afpr since its the cheapest mod i can do next. Just curious what mods and what psi you guys run your fp at and if you noticed any gains. Next mod will be pullies then i might go roller rockers then gears.
Old Oct 24, 2006 | 08:35 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
I went from stock to 49 Psi. Seen no increase in performance.
Old Oct 24, 2006 | 10:04 PM
smallblock383's Avatar
Car: 1991 Z28
Engine: 383 TPIS Mini Ram
Transmission: D&D Perf Viper/GM T-56
Axle/Gears: 3.73's Eaton Posi
I agree when I was running my TPI setup before switching to the mini ram I was set at 50psi. I didn't have that seat of the pants preformance gain. My own opinion is that I really didn't need it till I upgraded to a larger injector. And even then I did't notice anything either. Guess its like the chicken and the egg theory.
Old Oct 24, 2006 | 11:04 PM
Vader's Avatar
Mine is set at about 44 PSIG - Just like the original FP setting. I've done the rest of the tuning with teh PROM, but there is only so much to be had from a stock 305 with a factory "LA" cam.
Old Oct 25, 2006 | 06:20 AM
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
fuel pressure
It seems a couple of people said they gain a tenth or two tenths upping the pressure. My car has alot of free mods in exhaust and i feel i let alot more air in and exhaust out but never touched fuel. And its the next cheapest thing i can do. Pullies will probaly be next. I really would like to save my money down the road and get 3.70 gears installtion kit 3 series 9 bolt posi and a t/a performance differential cover.
Old Oct 25, 2006 | 10:38 AM
500hpc4's Avatar
Car: 1988 C4 corvette
Engine: 383
Axle/Gears: 3.42 dana 44 MW axles
I dont think you are going to see any gains unless you are running out of fuel at the stock setting. But for the record I am running 45 psi and 36# injectors. My AFPR is a holley and it works fine.
Old Oct 25, 2006 | 11:49 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
my air/fuel ratio was around 12.2 average. and i'm stock L98 with exhaust. thats abit rich as it is. more fuel pressure will make it more rich so i dont think thats what u want to do. i'd keep it stock pressure. more fuel pressure does help increase atomization of the fuel which is great but it does add abit more fuel. so if you do see power increases, it might be because your motor is runnin out of fuel
Old Oct 28, 2006 | 01:05 PM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
https://www.thirdgen.org/optimal-fuel-pressure
Vintageracer
Jan 10, 2020 05:33 PM
86IROC112
Aug 17, 2015 02:00 PM
Street Lethal
Aug 14, 2015 08:25 PM
Sanjay
Aug 12, 2015 03:41 PM
92purpz28
Aug 11, 2015 02:30 PM
