if I get a new Vortec 350
Old Oct 30, 2006 | 11:18 AM
Polecat's Avatar
if I get a brand new Vortec 350 longblock, I see SD makes these new TPI intakes, can I use this to bolt my stock 305 TPI to a newer Vortec 350?? Not looking for major power increases, just mild driver.
TPI Vortec Lower Intake Baseplate :: 12498060 - SDPC
thanks in advance,
Old Oct 30, 2006 | 11:49 AM
3rdgenZ's Avatar
Car: 1985 Z28
Engine: 85 L98
Axle/Gears: stock 10 bolt-3.73 eaten posi
yea that will work good, but you'll need some parts for that 350.
you'll need 22# injectors, L98 or LT4 knock sencor, ESC module for a 350, and of course a new prom burned.
Old Oct 30, 2006 | 11:58 AM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
I'd get a Holley Stealth Ram before I'd buy a $400 TPI base plate.
Old Oct 30, 2006 | 01:10 PM
Polecat's Avatar
yea but a Stealtthram is like $1200+ and this is for a street daily car, don't need huge power.
So the TPI will work fine with the Vortec 350, just a few mods, knock sensor varies and maybe burn a new chip? What's a stock 305 injector size??
Old Oct 30, 2006 | 01:24 PM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
19# for a 305, 22# for a 350.
Old Oct 30, 2006 | 01:40 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Vortec 4.3/305/350 used injectors rated at 19# @ 43.5 psi, but ran them at 60 psi for 24#.
Old Oct 30, 2006 | 01:54 PM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
I didnt know this, My buddies got a 89 GTA with a 350....we used to run the same Fuel pressure (Mine being a 305, his being a 350). Now its different now that I have 24# injectors after I redid everything on my car. But he was never close to 60 PSI on his 22#injectors. I actually advanced his timing a couple degrees, and turned up his fuel pressure to 48psi. His car runs fine. But, it was nowhere close to 60psi for a stock setting.
Old Oct 30, 2006 | 02:31 PM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
Huh?!? I paid less than $600 for converting from TPI to the Holley Stealth Ram.
Old Oct 30, 2006 | 02:39 PM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
When did the Holley Stealth Ram become $1200+? Think you thinking of the SuperRam.
The rest of the TPI intake should bolt up fine and you could probably keep your injectors with a burnt prom if you can get into chip burning.
Old Oct 30, 2006 | 03:13 PM
Polecat's Avatar
I just saw here, if you guys know where I can get a Stealthram, please get me a part number, place to buy,...for $600ish, heck year that'd be the way to go....
JEGS High Performance - Holley Stealth Ram MPI System
Old Oct 30, 2006 | 03:21 PM
Polecat's Avatar
AH! You mena the Weiand, will these work on a Vortec, if so, use stock wiring harness, get new injectors, etc??
JEGS High Performance - Weiand Stealth Ram EFI Intake Manifolds
Old Oct 30, 2006 | 05:16 PM
3rdgenZ's Avatar
Car: 1985 Z28
Engine: 85 L98
I think for a daily driven car a tpi setup will be more fun. dont get me wrong the stealth ram is beter at makeing more hp, but the TPIs low end grunt is just too fun for a street car.
Old Oct 30, 2006 | 06:16 PM
Polecat's Avatar
so far I'm still leaning towards a stock Vortec 350, the SD manifold and stock TPI, or heck with it, Vortec 350, Hotcam and RPM intake and Holley carb.
Jorlain
Oct 8, 2015 01:57 AM
86CamaroDan
Sep 29, 2015 10:08 PM
Stryker412
Sep 7, 2015 09:11 AM
85Special
Sep 3, 2015 04:21 PM
Formula_88AE
Sep 3, 2015 01:47 PM
