85 TPI Trans Am innacurate Overheating reading failure
Old Nov 2, 2006 | 02:04 PM
Erick LLaguno's Avatar
Car: 1984 Black Trans Am T Top KARR Knight Rider Replica
Engine: 305 V8 carburated
Transmission: 5 speed Manual Tranny
Hi everybody:
after riding in my 85 TPI TA for a while the engine temp is reading almost 260 :s but when you take the real temp of the engine with a laser gun temp. it will read that its working okay
also the temp of the water is okay because its NOT Boiling , and watter is flowing good in the engine.
The mechanic told me that it might be a bad reading from the gauge
keep in mind that my car is using an inacurate MAF sensor (i just ordered the correct MAF sensor) but my mechanic thinks that the MAF has nothing to do with this overheat reading from the gauge
also there is a choke light iluminated in the gauges that is caused because the MAF is not reading properly (my mechanic put an scanner to read any failure from the computer)
Any ideas? i am lost here
Old Nov 2, 2006 | 02:37 PM
Polecat's Avatar
I would just get a new aftermarket oil pressure/temp gauge if you know the factory one is faulty.
Old Nov 2, 2006 | 03:00 PM
87tpi7749's Avatar
Car: 1987 Iroc, 1987 MCSS TPI
Engine: 5.7L
Transmission: 700R4 in both
Me too, choke light on a TPI car?
Old Nov 2, 2006 | 03:22 PM
pmpn's Avatar
Car: 1989 GTA
Engine: 5.7 TPI
Transmission: A4
I wouldn't trust a laser gun. Put a scanner on the ECM and check it before you go spending money.
mustangman65_79
Sep 1, 2015 03:51 PM
beachrodder
Aug 25, 2015 08:05 AM
Sanjay
Aug 12, 2015 03:41 PM
mizz0313
Aug 12, 2015 06:45 AM
BOOT77
Aug 10, 2015 12:20 PM
