fuel pressure
Old Nov 8, 2006 | 05:37 PM
jjlabinski's Avatar
Car: 84 firebird T/A
Engine: shinny 350
Transmission: slush box L65
Axle/Gears: Torsen "3.73"
fuel pressure
what should my fuel pressure be with car not running and key on?
I have 24 lb accel injectors
Why after when I turn the key to on position my fuel pressure goes up to about 50 then immediately falls off to about 15 lbs?
thx
jeff
Old Nov 8, 2006 | 11:14 PM
robert1's Avatar
50 is a little high, for 24's, unless the engine needs the flow. Secondly, your regulator, or injectors, might be bad since it bleeds off so bad. It should hold that pressure for quite a while.
Old Nov 9, 2006 | 10:38 AM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
agreeed. Did you change the constant in the prom aswell ? Set it to 24 lb's
Old Nov 9, 2006 | 11:28 PM
jjlabinski's Avatar
Engine: shinny 350
yeah, constant was changed and both injectors and regulator are new outa the box.
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
