Painting TPI runners
Old Nov 21, 2006 | 11:29 AM
RacerM's Avatar
Car: 1992 Firebird
Engine: 383 Stroker
How hot do the runners get on a Tuned port system? I am going to paint mine, and I was wondering how hot they got so I can determine what type of paint to use.
Old Nov 21, 2006 | 11:40 AM
dave-92gta's Avatar
Car: 92 trans am/ 93 dodge spirit V6
Engine: L98 V8 - 350
Transmission: TH-700-R4
run your car, touch a themometer to it. you will know. you could probably rent a thermal one or find a buddy with one. local shop should lave one. im sure if you passed them some cash they will let you read the temp. i would use some high heat paint. it does nto look as good, but it would look like sh it if it starts to come off
Old Nov 21, 2006 | 12:12 PM
Guest
Guest
Posts: n/a
Just use some engine enamel, they make it in any color you'd want.
Old Nov 21, 2006 | 12:51 PM
Vader's Avatar
Spray enamel. "Import/Drifter Chrome" is OEM the color.
Old Nov 21, 2006 | 01:36 PM
RacerM's Avatar
Car: 1992 Firebird
Engine: 383 Stroker
i do not have the TPI set up on my car, so it will be hard for me to take the temp of them. my car was carburated. The runners are too dinted to polish. I already tried that and it looked like crap after I shined one side. Sense i cannot afford a new set, i am going to paint these. I found a nice color that i am going to paint them. i dont believe they get any hotter then 180 or 200 degrees.
Old Nov 22, 2006 | 02:31 PM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
I painted mine with 1200 degree aluminum from Dupli-color and then cleared it with the same high temp clear. Color changed from an almost ceramic coated color to a darker titanium colr which loos cool. Haven't drove it much since I finished the swap last weekend but at normal engine temps (160-180) no problems yet.
Old Nov 22, 2006 | 02:46 PM
dave-92gta's Avatar
i was looking to de the same for my slp runners. i was going to do waht i told you to do, in fact i jsut got the gun to check temps. i want it for other things to not jsut that. anywho i got some of that 1200 degree paint. waht would have a better shine? the enamel or the aluminum paint? does anyone have any picks of their cars painted with either?
Vintageracer
Jan 10, 2020 05:33 PM
tazs2000
Jul 15, 2017 08:44 AM
NBrehm
Aug 25, 2015 11:49 PM
Sanjay
Aug 12, 2015 03:41 PM
