85' 305 tpi wont start
Old Nov 29, 2006 | 01:11 AM
tlocke21's Avatar
Car: 85' CAMARO z28
Engine: tpi 305
Axle/Gears: 3.23 posi
first off blew a head gasket changed it.......bad compress in 4th cylinder.....now reading 175 psi on all cylinders....computer wouldnt let me diagnois codes....replaced it.....checked timing to see if distributor was 180 out......not tha problem.......then tested fuel injectors all tested good 16 ohms resistance.....brand new fuel pump.....all cylinders getting spark.....????.....so whats the problem
Brcharrelson
Aug 26, 2015 07:47 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
