Help! Need to buy a new distributor from Summit Racing. Which one?
Old Dec 5, 2006 | 12:00 PM
Dr G's Avatar
Hi there,
I need to buy a new distributor for my 1989 GTA with the 350ci TPI engine, and I need to be able to buy it from Summit Racing as I'm ordering a 'batch' of parts from them in the next week.
Will this model work?
Summit Part No:- MSD-8366.
http://store.summitracing.com/partde...=16383&N=700+0
http://www.msdignition.com/dist_2.htm
Is this a small cap HEI distributor? Or a large cap model?
Many thanks for any help you can offer!
Gordon
Old Dec 5, 2006 | 05:28 PM
brutalform's Avatar
That would be a small cap, dual connector distributor.
Old Dec 5, 2006 | 08:16 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
If you want to waste money it'll work. I personally would just put a new cap, rotor and internal pickup coil on your stock one and be done
Old Dec 5, 2006 | 08:47 PM
burnout88's Avatar
Car: 88 IROC
Axle/Gears: 10 bolt 3.73
I am running the MSD unit. Very nice piece. After I put it in I the noticed car started much easier and had a smoother idle. You may want to order it from JEGS it is cheaper. Only 262.99 at Jegs. Or at least have Summit price match it.
http://www.jegs.com/webapp/wcs/store...hTerm=121-8366
Old Dec 5, 2006 | 11:16 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
If you really think about it, theres only 2 things in the distributor. The rest is cosmetic. Pickup coil and ignition module. To the one who spent 269, yours started faster probebly due to an 12 dollar pickup coil inside the distributor. Unless your shaft is bent, gear is shot or something else major, your current one with 80 bucks for a rebuild and it'll work like new.
Old Dec 6, 2006 | 04:51 AM
Dr G's Avatar
Mkos, I've got the engine out for replacement at the moment and the cap, coil, module, leads are all less than a year old. However, the distributor shaft is rather rusty. Presumably, at some point in the past a lot of loisture has got in. It certainly doesn't look reuseable.
Thanks!
Thanks Burnout. As I said, I have to get the products from Summit but I'll get them to price match it.
Old Dec 6, 2006 | 06:25 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Thats a good reason then!! If you do a search from a while back ,there was a batch of users who complained about he MSD unit in conjuntion with the Edelbrock base and inproper fitment. May want to look into it if using that base.
Old Dec 6, 2006 | 06:29 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
the shaft that you see on the outside is not what turns.
I am all for rebuilding the used one. check for excessive end play and get a new gear, module, pickup-coil and clean it all out really good
for the money rebuild
Old Dec 11, 2006 | 12:35 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
Well since I am an uptight guy and need everything new (dont worry about money its my money) I am buying the HEI cap and rotor kit, I HAVE msd wires, buying ac delco iridium plugs, msd billet alternator at 130amp (am installing alternator underdrive pulley so thats why I'm buying 130amp), MSD 3hp brute starter, optima battery (red top). Sounds like a BOMB *** ignition to me. Thats what I am going with and will tell everyone how the car runs..........................................................
NEXT SUMMER 2007 BEGINNING OF MAY.
Old Dec 11, 2006 | 12:55 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Where in Cleveland are you located?
But the 3 major parts to the ignition system is missing for your upgrade.
Old Dec 11, 2006 | 02:11 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
i've got that MSD unit as well. It is a very nice looking peice. I personally wouldn't buy one, too expensive, but I got mine when I sold my 86 Trans Am for parts and cash. The HSR intake and MSD dist. that I got in the trade were brand new so I just put them on my Formula.
Old Dec 11, 2006 | 04:01 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Located in Garfield Heights. What 3 parts.....wait...let me guess, ignition box, ignition module (inside cap), and tuning?
Old Dec 11, 2006 | 09:25 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Ignition coil, ignition module and the pick-up coil which is in the center of the distributor. It connects itself to the ignition module via the white and green wires under the cap. I live over in Independence and my GF with her procharged RS lives in bedford.
Old Jun 11, 2007 | 05:12 PM
Dr G's Avatar
Re: Help! Need to buy a new distributor from Summit Racing. Which one?
Just an update for you:- I got this distributor and installed it with the new crate engine and it works really well. Well packaged etc.
Old Jun 12, 2007 | 08:37 AM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Old Jun 12, 2007 | 01:26 PM
brutalform's Avatar
Old Jun 12, 2007 | 01:32 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Originally Posted by brutalform
No offense but why do you think BOOBIES are crazy? I think anything I like is *******....because everyone loves *******...well except..you know. LMAO.
Brutal is for not liking *******
86CamaroDan
Sep 29, 2015 10:08 PM
New2Chevy
Sep 28, 2015 12:35 AM
Gunsbee
Sep 7, 2015 07:10 PM
Jackrabbit501
Sep 2, 2015 09:14 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
