My 305 has 350 balancer.
Old Dec 6, 2006 | 09:02 PM
ta3ff's Avatar
Car: '89 Camaro RS
Engine: none
Transmission: none
Axle/Gears: 4th gen 3.42 posi
I'm rebuilding a 1990 305 TPI engine, right now it head-less so I can port and polish them. The crank is at 0* TDC #1 piston all the way to the top. I installed the a new timing chain, put the timing cover on. When I went to install the new hamonic balancer I noticed something wrong right away. The timing line on the balancer was in the middle. My old one(balancer) lines up pefectly with the timing cover. The timing marks are on the right hand side of the cover, so it's at the 2 o'clock position.
The parts store guy said I was running a 350 balancer on a 305. It is skinnier than the 305's. The engine ran good, no engine vibrations.
Should I recheck my timing chain and why is the balancer different on a 305 when everything but the pistons are interchageable?
Old Dec 6, 2006 | 09:24 PM
Fast92RS's Avatar
Car: 1992 Camaro RS
Engine: 383 SuperRam
Transmission: 4L60
Axle/Gears: 3:23 Posi
GM only lists one part number for 305 and 350 balancers for 1990. I also looked it up at NAPA's web site and they also list one part number for 305 and 350's. I would go back and ask the parts store guy if he knows what he is talking about.
Also maybe you should post this question under the tech/ general engine forum.
Old Dec 6, 2006 | 09:36 PM
ta3ff's Avatar
Car: '89 Camaro RS
Engine: none
Transmission: none
So I can use a 350 balancer? If so, cool. Where can I get that info, DerekKraese?
Old Dec 7, 2006 | 08:57 AM
Fast92RS's Avatar
Car: 1992 Camaro RS
Transmission: 4L60
I would still make sure you have the correct part. You can go and look at Napa online to find the part number. I will Post the GM part # on friday I have to look it up again. But I think 87/ 88 - 92 V8's list the same balancer for 305's and 350's.
Old Dec 7, 2006 | 11:52 AM
Vader's Avatar
Both engines used a neutral balanced HB, so it really doesn't make a great deal of difference.
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Dwayne614
Sep 28, 2015 08:33 AM
theurge
Aug 21, 2015 12:46 PM
st.evel07
Aug 13, 2015 06:15 PM
