Throttle Body Hose Line problems
Old Dec 11, 2006 | 02:26 AM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
For those who know your throttle bodies and vacuum lines. Does anyone know on the passenger side of the throttle body the top port has a thick hose about 4inches long connect to a hollow stick(vacuum line to something)
That stick or stem or whatever platic line it is is coming up from the lower part of the engine behind the alternator. Does anyone know what it is and where it goes.
I have a low vacuum to the point when i put my fingerof any hose line i cant feel anything before or after i rev up the engine at the throttle body. And i cleaned my plenum and have a throttle body with new IAC.
The EGR valve seems to get just enoguh vacuum to keep the check engine light from coming on but if something is clogged else where i want to know about it and fix it.
So my next place to look is where that plastic line goes to.
I have a 305 5.0 TPI Fuel Injected V8 Trans AM 1986.
Any help and any ideas would be grealty appreciated.
Old Dec 11, 2006 | 07:09 PM
hoseman007's Avatar
Car: 92 RS/ 87 T/A
Engine: 305/L98
Transmission: 700R/700R
Axle/Gears: 3.42 Posi/3.27 Posi
That line goes to the passenger side valve cover the other one goes to the charcoal cannister.
Old Dec 11, 2006 | 07:41 PM
Bobby_80s's Avatar
Axle/Gears: no idea
yeap I see it now thanks a lot.
Old Dec 11, 2006 | 10:20 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Besides knowing where they go, its best to know what they do
If you ever have a problem you'll know what might be the cause.
The top one is for bringing clean air into the engine through the intake filter.
This air is then drawn out of the crankcase by the PCV valve in the opposite valve cover.
This port is in front of the throttle blades.
This keeps fresh air circulating, good air in and bad air is pulled out of the PCV by engine vacuum and gets reburned.
The lower hose is a connection behind the throttle blades and is a source of full time vacuum for the charcoal canister to "purge" fuel tank vapors and keep the enviornment cleaner. When the purge solenoid is energized, the vapors are pulled into the engine and burned.
HTH
Old Dec 12, 2006 | 10:00 PM
S105.7's Avatar
Car: '87 S10 Blazer & '91 RS
Engine: L98 & L03
Transmission: 700R4 & T5
Axle/Gears: 10 Bolt/3.73/3.42
anyone know if the plastic hard lines are still avaiable? mine are cracked to hell. id just assume keep all that smog gear, it doesn't hurt anything.
1992 Trans Am
May 10, 2023 07:19 PM
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
lakeffect2
Aug 23, 2015 08:44 AM
justin57
Aug 20, 2015 07:05 PM
