l98 build up
Old Dec 25, 2006 | 02:36 AM
ristine's Avatar
l98 build up
I would like to build my 350 tpi from the cam up. I need recomendations on what cam and heads to use. I would like to use a hydrolic roller rocker cam. I also need help with the intake and what tpi system to use. Im looking to get around 450 hp out of my car. I have around $5000 to use but want to use it the best ways I can. Thanks for the advise. Ramey
Old Dec 25, 2006 | 09:17 AM
Rob Wade's Avatar
Car: 89 jaguar xjs convertable
Engine: 89 L98 5.7 TPI
Axle/Gears: 3.23 dana 44
I think your goal of 450 HP from a TPI set-up might be a bit to lofty. You may need to switch intakes to a superram or TPIS miniram or holley for those HP #'s. How is the car used? Your combination needs to be planned out carefully so you get the most performance.
Old Dec 25, 2006 | 10:49 AM
Gunner823's Avatar
Engine: L98 355
Axle/Gears: 3.70
If you want 450 hp...do a cam swap, a set of heads, and a blower. Should cost you around $5000. Assuming you already have headers, exhaust, etc.
Old Dec 26, 2006 | 03:33 PM
danziger's Avatar
Car: 1991 Formula Firebird
Engine: L98 with headers/exhaust
Axle/Gears: 3.23 10-bolt
450rwhp or 450fwhp? Auto or manual? You could do a budget 383 and spray it...
Old Dec 27, 2006 | 02:38 AM
ristine's Avatar
l98 build up
I know that I need to change my heads cam intake and tpi set up but I was wondering what brands and sizes you people suggested to get the 450 hp area. Mainly brands and sizes of cam and heads a good combo that will work. I was thinking comp hydrolic roller cam but dont know which one and unknown on heads. thanks
Old Dec 31, 2006 | 08:04 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
What happened to "subscribe to this thread?"
I'm pretty much in the same boat so you guys'll be helping us both.
Old Dec 31, 2006 | 10:05 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
i agree with the blower my 305 is pushing an estimated 450hp/475 ft/lbs of torque at the flywheel with a 15% loss from the t5 drivetrain, i dyno'd 381hp/400 ft/lb of torque, sound about right guys?
Old Jan 4, 2007 | 12:14 AM
ristine's Avatar
another question
Are the pistons in a 1988 l98 flat top or curved??????
Old Jan 4, 2007 | 06:20 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
How about a 92 L98 GTA? I opened mine up and found flat tops. I didn't think GM built these cars with flat tops.
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
Tarizza
Sep 24, 2015 12:57 PM
Mongoose462ci
Sep 16, 2015 11:46 PM
Winchester1094
Sep 15, 2015 09:48 AM
