what are these connectors for?
Old Dec 25, 2006 | 06:31 PM
johnnyboy's Avatar
Car: '82 formula clone, 95 saab 900se
Engine: 350 vortec'd tbi, 2.0L turbo
Transmission: 700r4, 5 spd
Axle/Gears: 10 bolt 2.77 open
i'm mocking up my tpi setup before i go ahead and put it on my car because i want to be as sure as i can that it'll just bolt right up without any problems. but i need some help identifying some of the connectors.
Old Dec 25, 2006 | 08:16 PM
wackytower's Avatar
Car: 1985 Trans Am
Engine: Superramed 406
Axle/Gears: 10 bolt 3:73
#1 is ac compressor(assuming the first 2 pics are the same connector)
#2 is iac
#3 im not sure it would be better too know the wire colors
#4 not sure
#5 egr solenoid?
#6 oil pressure sending unit
#7 ac switch that goes on the ac line
#8 It kinda looks like aalternator but Im not sure I cant recall if its on that harness or not(its been a while since ove had mine apart
Old Dec 25, 2006 | 09:08 PM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
#3 is the TCC solenoid
#8 looks to be the A/C pressure switch
#5 looks like the alternator
#6 looks like the EGR vacuum solenoid
#7 looks to be the brake pressure switch that connects on top of the proportioning valve.
All these are based on a speed density harness and a MAF harness may be different.
Old Dec 26, 2006 | 09:31 AM
S105.7's Avatar
Car: '87 S10 Blazer & '91 RS
Engine: L98 & L03
Transmission: 700R4 & T5
Axle/Gears: 10 Bolt/3.73/3.42
ok my turn...
3. TCC or IAC
4. reverse lights
5. ???
6. EGR
7. oil pressure
9. coolant fan
Old Dec 26, 2006 | 09:33 AM
Vader's Avatar
Wire colors are going to help a lot. Looks like a Firebird '86 TPI setup, maybe '85.
Old Dec 26, 2006 | 11:25 AM
johnnyboy's Avatar
yeah it's off of an '86 i took it all off the car myself but i wasn't smart enough to label all the connectors
Old Dec 26, 2006 | 01:43 PM
Vader's Avatar
Just list the wire colors in each of the "mystery" connectors, and we'll get you very close to solving the mystery.
Old Dec 26, 2006 | 01:51 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I believe 6 is the IAT / MAT. Remember you have a 12in extension between that and the normal connector under the PLenum. Its wires are tan and black just like the IAT / MAT ones. I think 4 is the VSS on the firebirds elect speedo. 9 is the fans.
Old Dec 26, 2006 | 02:10 PM
johnnyboy's Avatar
'86 didn't have an electronic speedo though right? 87 and up i thought?
Old Dec 26, 2006 | 05:21 PM
Vader's Avatar
'86 Firebirds had the electronic speedometer. Mine does.
#1. TPI Overview
#2. Alternator Field
#3. Same as #2
#4. Transmission Connector (TCC Solenoid and Top Gear Switch)
#5. Main ECM/Fuel Pump Power (if both wires are orange)
#6. ???
#7. MAT Sensor (under plenum, tan & black wires) or EGR Solenoid (gray & black/pink wires)
#8. Oil Pressure Sensor (for gauge) or Brake Warning Switch (depends on wire colors)
#9. A/C High Pressure Cutout Switch
#10. Cooling Fan Motor
91 SrS
Oct 7, 2015 04:32 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
meeklay812
Oct 1, 2015 03:46 PM
tmork454
Sep 29, 2015 06:33 PM
Gordonr1973
Sep 29, 2015 11:59 AM
