need recommendation on valve covers to work with 1.6 rr's..
Old Dec 31, 2006 | 03:12 AM
LVZ2881's Avatar
Car: 1988 IROC
Transmission: 5 speed
Axle/Gears: 3.08 Posi 10 Bolt w/ aluminum drums
I installed comp 1.6 rollers on my '88 TPI, and cut the bracing out of my factory valve covers. now they are either warped or hitting the rockers, but either way, they are not sitting flush on the heads..
I would like a set of tall centerbolt covers.
my question is: will tall covers with baffles clear the rockers, or do I need non-baffled ones??
Old Jan 4, 2007 | 08:33 PM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Transmission: 700r4,2500 stall
Axle/Gears: G80,10 bolt 3.42's
I had to get the tall valve covers when i went to 1.6 roller rockers.Had the same problem.You should be able to get them from your locaal speed shop or on line at jegs or any other performance parts place. I got mine at Pace performance GM parts.I used non baffeled.
Old Jan 4, 2007 | 10:32 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Hmmm. The stock covers worked just fine with 1.6 roller rockers and my ZZ9 cam. I was using Trickflow heads.
Now with the motor I'm installing now I had to go with the tall covers. This is with the Comp Cams XFI-268 cam and Dart Pro One heads. I also used taller 7/16 studs.
Old Jan 4, 2007 | 11:57 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
We are using the stock valve covers on my 355 083 heads with comp pro mag 1.6 rockers. Sits flush with a one turn preload. Antyning less and the top of the permaloc nut is hitting the top of the valve cover.
Old Jan 7, 2007 | 09:34 AM
Rob Wade's Avatar
Car: 89 jaguar xjs convertable
Engine: 89 L98 5.7 TPI
Axle/Gears: 3.23 dana 44
Heres what I used on mine, baffled. Go to summits website PRO-141-131 Very happy with the quality. Assuming of course you used the correct narrow body self aligning rockers.
1992 Trans Am
May 10, 2023 07:19 PM
NBrehm
Aug 25, 2015 11:49 PM
db057
Aug 22, 2015 08:17 PM
Street Lethal
Aug 12, 2015 11:33 AM
mustangman65_79
Aug 8, 2015 01:18 AM
