whats the best fuel pump
Old Jan 4, 2007 | 08:01 PM
johnnyboy's Avatar
Car: '82 formula clone, 95 saab 900se
Engine: 350 vortec'd tbi, 2.0L turbo
Transmission: 700r4, 5 spd
Axle/Gears: 10 bolt 2.77 open
whats the best fuel pump to buy for my 305 tpi swap and where should i get it from?
anyone have a used one for sale?
Old Jan 5, 2007 | 10:44 AM
BOTTLEDZ28's Avatar
Transmission: A4
a stock replacement wil work fine for your 305 swap. If you feel you want a better name brand pump then Holley and Walbro make good pumps as well. Its all on how much you want to spend. I would NOT, I repeat, NOT install a used pump. Its just not worth the hassle. Buy a new pump and be done with it. you may also want to check on the replacement pumps for the GMC syclone and typhoon as the pumps used in those trucks should also work in your car. Buy a new O ring seal for the tanks sending unit while your in the dept. Follow the directions to the T and all should go well. DO not jam the sending unit in the tanksince you will bend the float lever and throw off the gauges accuracy.
PS.
PS. DO NOT CUT A HOLE IN THE TRUNK AREA TO ACCESS THE PUMP. DO IT THE RIGHT WAY.
Old Jan 5, 2007 | 08:18 PM
johnnyboy's Avatar
the gauge isn't very accurate anyways, i get like 100 miles out of the first 1/4 tank and then like another 100 out of the next 2/4
Old Jan 5, 2007 | 08:57 PM
hairbear's Avatar
Car: 1997 SS 30th Anniversary
I left the stock pump in the tank on my RS and just did an inline. Works great and gettin the needed 50ish psi needed to run the TPI that I changed over to
Old Jan 5, 2007 | 09:14 PM
thirdgenlover's Avatar
Car: 87 trans am
Engine: 350 TPI bored .040 over
Transmission: modified 700r4
Axle/Gears: stock spline, 3.73 Eaton posi
its a big job on some on ours, can anyone tell y they wouldnt cut a hole. i heard that you have to take the rear end out, and on mine i would have to take the exhaust out.
Old Jan 5, 2007 | 09:30 PM
BOTTLEDZ28's Avatar
Transmission: A4
first off its not worth it because in order to get the entire sending unit with the pump out of the tank, you would need to cut a massive hole in the car. The HARD lines come out of the top of the sending unit and travel along the top of the tank toward the fronf of the car. they then bend downward behind the seat a little bit so you would need to cut a hole out that big in order to pick the sending unit straight up without bending or ruining the hard lines. Trust me, its not worth it. Take my word for it because I tried a long time ago. Your thoughts of this 8"x8" square hole turn in 20x20. Then you have to weld it back in there when your done and thats not the easiest thing to do some people.
I know it sucks to drop the rear and pull the exhaust off but it is the only proper way of doing this procedure.
Old Jan 5, 2007 | 09:54 PM
Car: 87 trans am
well is another good opinion would be to leave the stock one in the tank and just put an inline one in, i am new to the fuel deliver thing
Old Jan 5, 2007 | 10:02 PM
BOTTLEDZ28's Avatar
Transmission: A4
I wouldnt add an inline pump. I would just replace the tired or busted pump with a new one in its stock location. I dont claim to be an engineer or anything in this dept but I think you will making things worse with an line pump. Someone tell me how you can have one pump pushing and then 3-5 feet down the line have another pump sucking and pushing at the same time.
PS, I mean maybe I am wrong here but I think it would just be easeir to install the proper replacement pump and be done with it
Old Jan 5, 2007 | 10:22 PM
Car: 87 trans am
shoot, now i am stuck with a Dilemma, i am all about doing it right, but i dont have much time. i go to school mon thru thur. work fri and sat and church sun. hardly never any breaks. my car now, my pressure at the rail is good, flow=bad. its a stock 350 .030 over, shorties true duals, mods later, maybe engine even later, need pump for this and probably have to get a regulator then. after exhaust was done, got a code for lean exhaust
Old Jan 5, 2007 | 10:25 PM
BOTTLEDZ28's Avatar
Transmission: A4
welcome to the real world of building cars as a hobby. Get a few more opinions on this and then go from there. dont take my advice as the only advice out there.
Old Jan 5, 2007 | 10:31 PM
Car: 87 trans am
yeah i know, thats what makes it fun you have a 383, an engine that i would love to have and it sounds like you have done it, that is an expert in my opinion
Old Jan 5, 2007 | 10:36 PM
BOTTLEDZ28's Avatar
Transmission: A4
This site will help you out a ton with any questions you may have. its helped me a ton over the years and has allowed me to do all the work on my car myself. Now Im guessing you have a 305TBI and are now swapping to a 305 TPI right? Maybe this question you have willbe better answered in the engine swap section of this board. Give it try over there?
Oh and why in the heck are you putting another 305 back in the car. a 350 can be found anywhere for cheap money. ALL of your parts will fit the 350.
Old Jan 5, 2007 | 10:40 PM
Car: 87 trans am
its a 350 tpi bored .040 over in there right now, sorry i have been saying it is .030 over
Old Jan 5, 2007 | 10:42 PM
BOTTLEDZ28's Avatar
Transmission: A4
ohh well in the first post you said 305.
Old Jan 5, 2007 | 10:44 PM
TexasSilhouette's Avatar
Car: 1991 TransAm GTA 350
Engine: 350 SBC TPI
I encourage folks to go to a high volume pump if they are doing any mods of any consequence, especially adding Nitrous.
Old Jan 5, 2007 | 10:46 PM
Car: 87 trans am
hairbear said that not me, my first comment is y you wouldnt cut a hole and that i heard that you had to take the rear end and exhaust out
Old Jan 5, 2007 | 10:47 PM
BOTTLEDZ28's Avatar
Transmission: A4
FWIW, I am running the Holley pump in my car. Its either the one in this link or one VERY similair to it http://store.summitracing.com/partde...5&autoview=sku
Old Jan 5, 2007 | 10:53 PM
Car: 87 trans am
i was looking at that one as well, i could tune that down for fuel deliverly to a 350 couldnt i, would computer do that or get a pressure reg.
Old Jan 5, 2007 | 10:55 PM
BOTTLEDZ28's Avatar
Transmission: A4
you will need an adjustable fuel pressure regulator to control the pressure to the PSI you need
Old Jan 5, 2007 | 10:58 PM
Car: 87 trans am
cool done deal then, thanks by the way i am slow what is fwiw, not use to the short versions besides like lol and imo
Old Jan 5, 2007 | 11:00 PM
BOTTLEDZ28's Avatar
Transmission: A4
for what its worth.
Old Jan 5, 2007 | 11:09 PM
Car: 87 trans am
ha ha ok im pathetic i know
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
