HELP!!DOES my 90 TPI MAP have a vacuum line that goes to it?
Old Jan 6, 2007 | 06:32 PM
87turboGN's Avatar
Putting car back together,can't seem to remember if my map had a vacuum line to it...everything else is hooked up right except a line that goes back into the loom toward the AC box and im assuming that is for the ac vent and whatnot..help me please,the stupid vacuum diagrams don't show a line to the MAP,thank you
Old Jan 6, 2007 | 07:36 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
your right, it doesn't show a vacuum hose going to the MAP.
it does have to have one.
here is a pic of a 92 TPI, its a little differnt but it should be close enough.
Attached Thumbnails HELP!!DOES my 90 TPI MAP have a vacuum line that goes to it?-map.jpg
Old Jan 6, 2007 | 07:44 PM
87turboGN's Avatar
Thanks alot..i'm still up in the air though......Do i just hook it to one of the ports right behind it?Does the fact that i am speed density affect anything?
Old Jan 6, 2007 | 08:08 PM
DENN_SHAH's Avatar
it goes right to one of the ports on the plenum
Old Jan 7, 2007 | 12:19 AM
87turboGN's Avatar
one port goes to hvac and one to fpr..where does Map go????
Old Jan 7, 2007 | 05:21 AM
DENN_SHAH's Avatar
i came off the vacuum port & put a T in the hose, one side goes to the MAP sensor & the other side goes to the hvac hose.
you do not want to T off the FPR for anything, if it starts leaking it would kill the MAP sensor or pump fuel inside the car if it was Teed into the hvac.
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
Sanjay
Aug 12, 2015 03:41 PM
apie2546
Aug 10, 2015 05:43 PM
squiggy2
Aug 9, 2015 09:30 PM
