Leaking injectors ?
Old Jan 8, 2007 | 07:35 AM
ino's Avatar
ino
Car: 87 firebird
Leaking injectors ?
Me and my brother worked on his motor and it keeps blowing his top o-rings on the injectors. He has a brand new 355 TPI with 22lb Ford racing injectors. I think he needs to check the fuel pressure but what do u guys think. Any and all help is appreciated.
Old Jan 8, 2007 | 06:43 PM
joejoe's Avatar
Car: red one
Engine: on the floor
Transmission: next to engine
Axle/Gears: the ones that turn
Fuel press. should be at 43.7lbs not runing, keep gauge on the valve (key off) see if the press. drops, if it drops fast you might have an injector (or 2) leaking....are you using GM O-rings?
jklein337
Sep 19, 2018 06:23 PM
92projectcamaro
Jan 18, 2016 08:00 AM
BAMiller
Sep 14, 2015 06:38 PM
greenyone
Sep 2, 2015 03:39 PM
