New way of TPI heater core Hose bypass?
Old Jan 10, 2007 | 01:41 PM
z28onTweenkies's Avatar
Car: 1992 Camaro Z28 & 2k3 Cadillac CTS
Engine: LB9
Axle/Gears: 3:43
When I bought my 87, the previous owner had the heater core fail on him. He bypassed the core, but did it in a way that left the hoses clamped to the failed core. What he did was run the 3/4 return hose (number 7 in the diagram) directly to the throttle body. At the throttle body, he took the tb hose (number 3 in the diagram) and used a plastic valve to join it with the 3/4 return line from the radiator. This bypassed all of the stock diverter valve and left it intact. I am going to correctly route the hoses this afternoon, but am wondering what kind of effect this re-routing of hoses can have on horsepower or general operation of the vehicle. What do you guys think?
Old Jan 10, 2007 | 01:49 PM
Fast92RS's Avatar
Car: 1992 Camaro RS
Engine: 383 SuperRam
Transmission: 4L60
Axle/Gears: 3:23 Posi
Just put it back the way its in the figure with or without the valve and just bypass the throttle body. You dont need that hot coolant running through the throttle body.
Old Jan 10, 2007 | 02:39 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Just plug the radiator nipple and the nipple on the intake manifold and your all set. Get rid of all the hoses then.
Old Jan 11, 2026 | 03:26 PM
chevypower91's Avatar
Car: 1991 Camaro Z28
Engine: 305 cid
Transmission: 5 speed
Axle/Gears: Posi/3:42
Re: New way of TPI heater core Hose bypass?
I apologize for reviving an old post. I am helping a friend to bypass his heater core. I wanted to know where on the throttle body the 3/4 return hose (number 7 is connected to, since the 3/4 line (number 3) is connected to it?
Tim Newton
Nov 26, 2022 03:12 PM
Cpd101
Jun 26, 2021 02:13 PM
silverado638
Oct 30, 2011 04:53 PM
closer
Jun 24, 2009 11:21 PM
lakeffect2
May 27, 2006 09:11 PM
