Rims for 91 z28 camaro
Old Jan 13, 2007 | 07:11 PM
Daisyduke060585's Avatar
I have a 91 Camaro, Z28. I am thinking of purchasing new rims. I want the
American Racing Torque Thrust II , polished and atleast 16s. What I need to
know is what is the backspacing, all that other stuff that I have to know to buy the correct size for my camaro. Please HELP!!
Old Jan 13, 2007 | 07:20 PM
Abubaca's Avatar
Welcome to TGO!
....well, this is the TPI forum, but the forum refers to the TPI motor itself, not the entire car. This should probably be in Appearnace and detailing, or Body and Interior. ...hehe, not really sure exactly!
.....but you're new, it's cool. Unfortunately I don't have the answer of the top of my head. Best bet would be an advanced search. Look under thread titles, not entire threads.
-Boob
Try this search result. It's a bunch of threads that'll probably help.
https://www.thirdgen.org/forums/sear...earchid=481301
Old Jan 13, 2007 | 08:06 PM
deadtrend1's Avatar
i think its 4.5". but dont quote me on it
Old Jan 16, 2007 | 11:01 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
You will be fine with a 4.5" bs on a 16x8 rim. You might want to consider a 255 on the rear with 245 on the front.
Old Jan 17, 2007 | 09:29 AM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
For the Formulas and T/As they have two specific TT2s in 16 x 8". The first has a 4" backspacing with -11mm offset and the other has 4.75" backspace with 5mm offset. I'm running 17 x 8" with the 4" BS and -11mm offset but if I had it to do over I'd get the fronts with 4" BS and 0mm offset. These specs should carry over for your Z with no problems.
Frozer!!!
Jan 19, 2024 04:55 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
Exxon Limited
Aug 9, 2015 08:13 PM
antares57
Aug 6, 2015 07:47 AM
