TPI Swap, VSS issues?
Old Jan 17, 2007 | 05:13 PM
crazymex83's Avatar
Car: '88 Firebird Formula 350
Engine: L98 TPI 350
Transmission: 700R-4
HI all,
I'm going to be helping with a TPI swap and we're trying to get a good idea of how feasable this is going to be. The TPI setup will be swapped into a 4WD S-10 Blazer and I've been reading about VSS issues. Mostly that the TPI VSS signal is at 2000ppm I believe and the blazer has a 4000ppm signal. The trans from an F-body cannot be used because of the transfer case, and I know there are VSS components that can be replaced to have the proper signal, and third I've read of how to override the VSS signal all together. Is it possible to change the TPI VSS signal to 4000ppm instead of all the other hassle? I have PROM equipment, just not much knowledge/experience. Thanks in advance.
(Sorry if this is in the wrong forum, I figured since its TPI specific...)
Old Mar 25, 2007 | 11:39 AM
JDF-Z28's Avatar
Car: 1983 Z28
Engine: GMPP 350, 92 TPI
Axle/Gears: Auburn gear posi, 3.08
Re: TPI Swap, VSS issues?
90-92 TPI 4000 pulse VSS, 85-89 TPI 2000 pulse
Old Mar 25, 2007 | 01:52 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Yep, just use a VSS from a 90-92 thirdgen with a 700R4.
Old Mar 26, 2007 | 02:57 PM
LeeH's Avatar
Car: 89 Firebird Formula
Engine: 389
Axle/Gears: Moser 4.11
Kevin
When you did your T56 swap what did you do about the VSS / ECM pulse differences? I ended up going with the Dakota Digital box. I alsoe went that route because of the 411 Moser rear I put in. Much easire than reprogramming the EXM...
Old Mar 27, 2007 | 01:44 AM
Kevin91Z's Avatar
A local guy machined the T56 tailhousing to use the stock T5 VSS unit. Sorry I cant find the pic.
Old Mar 27, 2007 | 11:49 PM
stingerssx's Avatar
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
So Kevin, you're still using my VSS? I guess it got some use seeing as how my WC T-5 swap didn't go too far!!
Old Mar 29, 2007 | 11:32 PM
Kevin91Z's Avatar
Sorry I dont recognize your user name, but Jerry did the modifying of my T56 bellhousing.
Old Apr 5, 2007 | 12:07 AM
stingerssx's Avatar
I'm the guy that you got that VSS from. Remember trading the non-electric VSS for the electric? You came to my pad, measured both to make sure, and I swapped you for free?
gta90
Sep 15, 2015 04:00 PM
NBrehm
Aug 25, 2015 11:49 PM
fonzie85
Aug 13, 2015 11:50 AM
Sanjay
Aug 12, 2015 03:41 PM
mizz0313
Aug 12, 2015 06:45 AM
