MISFIRING 305TPI ON PAAS. SIDE, RUNNING EXTREMELY ROUGH, WET PLUGS. I NEED SLEEP
I solved my service engine light problem, but it runs rough and has a misfire on passenger side. i pulled my new plugs out and they were blackend and wet, but didn't smell like gas or oil. its sounds like its around plug 6 and 8. So i then unplugged them one at a time and got a slight difference but it was extremely hard to tell. i cleaned the plugs only to have them do the same thing.
THINGS I HAVE NEW:
spark plugs
wires
dist. cap
rotor
ignition module
tested pick up coil resistance is 871
I have a cheap voltmeter don't know if thats y im not getting a reading on the ignition coil test.
I' m trying to let it go for a while , but i can't rest until its running right. I have Camaro on the brain constantly.
if anybody has any ideas please share your knowledge. This is my first TPI and I cannot let it win.
THINGS I HAVE NEW:
spark plugs
wires
dist. cap
rotor
ignition module
92camaroJoe
Aug 13, 2015 06:07 AM
