Why an AFPR?
Old Jan 21, 2007 | 09:21 PM
SheldonZ28's Avatar
Car: 89 IROC/05 RX8
Engine: LS1/LS1
Transmission: T56/T56
Axle/Gears: 3.42 GM/3.55 8.8
Why an AFPR?
Hey everyone.
Im looking into the BBK AFPR, as my engine is completely apart for a new cam.
What is the advantage to the AFPR, other then a higher fuel pressure?
What can i accomplish with a higher fuel pressure?
Is it worth the $100cad (with shipping, conversion, duties etc) for one of the items?
I will be using either stock injectors, or LT1 injectors, so if you can, list advantages etc with either injector.
Thanks for the help!
Sheldon
Old Jan 21, 2007 | 09:31 PM
lizardkng's Avatar
Car: 91 Z28
Axle/Gears: Stock
As I understand it, the fuel atomizes better under higher pressures.
Im probably way off the mark.
Old Jan 21, 2007 | 09:50 PM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Basically it was a way of tunning in the old days, if you can do your own chips then really you don't need one. To get full use out of it you really need to bring a car to a track or slap it on a dyno.
Old Jan 21, 2007 | 09:58 PM
Abubaca's Avatar
Eh, I dunno about that really. Sure different pressure can add tuneability due to a little more, or little less fuel, but the higher pressure will atomize better, so assuming it's tuned to that amount of fuel, the atomization alone should be beneficial.
Old Jan 21, 2007 | 10:00 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
You are buying go-fast-parts for what reason - to get more air into and out of the engine, more air, more power. So, if you got more air, you need more fuel. An AFPR is an easy way to get the extra fuel w/o changing injectors or the ECM chip.
Old Jan 21, 2007 | 10:02 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
Don't use the BBK afpr.
The BBK uses a crappy small bolt and it strips on top of the "can".
Spend a couple more $ and get a Holley
The Holley version uses a bigger "dial" about the size of a twoonie(or a silver dollar for you USA people) to do the adjustments.
I was too cheap, and made my own afpr and used a toonie for the dial.
Old Jan 21, 2007 | 10:48 PM
Tony89GTA's Avatar
Car: 89 GTA
Originally Posted by LB9GTA
I was too cheap, and made my own afpr and used a twoonie for the dial.
Old Jan 21, 2007 | 11:36 PM
Brisk's Avatar
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
nice home made afpr. I bought a used intake and it came with a fuel rail installed with an afpr which doesn't look to appealing to me. Its got a bolt on the top and a hole drilled into the side of the housing? I'm not sure yet if its going to leak, or what.. perhaps thats the way its supposed to be?
is it easy to make your own afpr, or did you just modify your BBK one after it stripped?
Old Jan 22, 2007 | 08:52 AM
88BlackZ-51's Avatar
sheldon when i get my motor ripped up in the spring i will sell u my afpr, and possibly those 113 vette heads.
Old Jan 22, 2007 | 12:39 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
In the tech section on the home page of TGO, there is an article on home-made afpr. I just used the toonie instead of a bolt.
Old Feb 17, 2007 | 08:34 AM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
Yup, better fuel atomization (which performs better) but not enough to where you need to change ecm programing, it compensates... you could fine tune it if you wanted, but don't have to...
Anyone use the TPIS one or know if it's another company's repackaged?
Raf
Yup, better fuel atomization (which performs better) shorter injector pulse, but not enough to where you need to change ecm programing, it compensates... you could fine tune it if you wanted, but don't have to...
Raf
Old Feb 17, 2007 | 02:16 PM
90 white Z's Avatar
Car: 90 iroc
Engine: 305 tpi
Holy crap guys check this out!!! TPIS AFPR which sells for $100 from jegs is only $50 on ebay.
http://cgi.ebay.com/ebaymotors/TPI-L...spagenameZWD1V
Old Feb 17, 2007 | 03:00 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Like I always say, I don't know if this is the norm, but I added 2 degrees of timing and bumped the FP up to 49 psi and had no increase in MPH at the track. Then I bumped the timing to 10, and also had the same result, no increase in MPH. I'm actually going to try lowering the FP this year and retard the timing to back to 8 and see what happens this year at the track.
Old Feb 19, 2007 | 01:07 AM
90 white Z's Avatar
Car: 90 iroc
Engine: 305 tpi
Would you recommend 8 over 6??
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
2012sergen11
Oct 13, 2015 07:38 PM
Reid Fleming
Oct 10, 2015 09:56 PM
alpine247
Sep 16, 2015 05:25 PM
355tpipickup
Sep 4, 2015 05:32 PM
