What's it called and Where can I get one?
Old Jan 25, 2007 | 11:57 AM
CriSSes's Avatar
I'm gathering the parts required to do the 165 to 730 swap. As far as removing the MAF is concerned, I've seen on the SD cars that there is a rubber/plastic assembly that connects the throttle body to the air filter shroud. What is this called and how/where can I get one?
Old Jan 25, 2007 | 07:16 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
This post belongs on the DYI Eprom board. There is a sticky or tech article on this very swap.
Old Jan 25, 2007 | 07:51 PM
CriSSes's Avatar
I thought I had put it in the DYI Prom section - Moderators, you may move it if you like. I have searched the board for this information and I have studied the article in the Tech section. The article in the Tech section tells you to use an aluminum can to connect the two pieces. I'd like to get the real part if possible. I have not found any information about this part which can be seen in the following link:
https://www.thirdgen.org/forums/cama...z28-350-a.html
Scroll down to the picture of the engine bay. The part that fits between the throttle body and the air duct. That's what I want to buy and I can't search for it when I don't know what it's called.
Please help me out here.
Old Jan 25, 2007 | 10:24 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
thats called the air duct or air boot.
here you go,
http://www.tpiparts.net/inc/sdetail/147
Old Jan 26, 2007 | 07:55 AM
CriSSes's Avatar
Thanks DENN_SHAH, got one ordered!
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
bschmale66853
Sep 30, 2015 08:11 PM
