best aftermarket base?
Old Jan 26, 2007 | 02:49 AM
bigchief's Avatar
Car: 1989 Firebird Formula
Engine: 5.7L 355 TPI
Transmission: 700 R4 with TCI rebuild kit and valve body mods
i bought the accel super ram base off JEGS and the casting on it says EDELBROCK, which i thought would have said ACCEL. i called them up and they said that accel uses the edelbrock casting...
do you guys know if its the exact same thing as the stock edelbrock base off summit???? or does accell like port it out or something....
i was also looking at the TPIS base manifold, is that completely compatible with the super ram upper manifold???
(i want something that is EGR and super ram capable) let me know guys, thanks!
Old Jan 26, 2007 | 11:43 AM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Which ever one you find the cheapest. They are now all made by Edelbrock.
Old Jan 26, 2007 | 12:35 PM
Fast92RS's Avatar
Car: 1992 Camaro RS
Engine: 383 SuperRam
Transmission: 4L60
Axle/Gears: 3:23 Posi
TPIS big mouth intake from what Ive read is just a ported out Edelbrock casting...
Old Jan 26, 2007 | 01:36 PM
Car: 1989 GTA
Engine: 369 TPI
From some I have seen I don't think TPIS even ports them out anymore.
Old Jan 27, 2007 | 04:58 PM
Steve Mack's Avatar
Car: 87 Iroc
Engine: modified 350
Transmission: high performance built 700R4
Axle/Gears: Strange S60 3:73
TPIS does port them out but charges another 75$ to do it. I just bought an Edelebrock base and measured the runner ports and they're about a 16th of an inch bigger than stock definitely going to need some porting to match the AS&M large tube runners I have.
Pac J
May 17, 2020 10:44 AM
thunder57
Nov 7, 2015 02:28 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
ndndndnd
Sep 28, 2015 08:00 AM
Damon
Sep 26, 2015 04:29 PM
