should i keep tune port
Old Feb 2, 2007 | 05:03 PM
K-9's Avatar
K-9
I just brought a 1987 IROC it has a 350 5.7 and I won't to get a lot more power out of it I won't to know if I should keep the tune port or should change it to carburetor.
Old Feb 2, 2007 | 05:21 PM
subliminal's Avatar
Im assuming won't means want
Anyways it all depends on what your goals are if you just want a low 13 sec high 12 sec car you can get away with porting the stock pleneum and getting new runners and a high flow intake manifold. I personally wouldnt get a carb, if you want to get something new get a Holley Stealth Ram intake.
Old Feb 2, 2007 | 08:32 PM
Dirtbik3r's Avatar
Car: 1992 Camaro RS - not real slow anymore...
Engine: SPDC 360 MAF EFI /w a Holley Stealth Ram
Transmission: T5 untill it blows up from to much torque
Axle/Gears: Ford 9" /w auburn pro & 3.89's
TPI is basically the wiring and switching grounds for the injectors. With this setup, it is almost identical to bank fire which fire an entire bank at once. What I think you're referring to is the intake which in stock form, chokes up high. I would grab the stealthram and keep your ecm.
grngryoutmyway
Oct 18, 2016 05:48 PM
69GTOby
Apr 18, 2016 02:34 PM
Nervous2
Oct 8, 2015 10:53 PM
eustodp
Sep 20, 2015 05:09 PM
m00n420
Sep 11, 2015 02:39 PM
