Fuel Filter Swap
Old Feb 4, 2007 | 10:00 AM
dp149's Avatar
Fuel Filter Swap
Very new to TPI..I have a 1989 formula firebird 350. want to change fuel filter. I have always had carb cars so easy. Looks pretty easy but I did a search and heard people talking about 0-rings and stripping nuts to the fuel filter. Other than buying a new fuel filter, do I need to buy new o-rings? I read about how to depressurize the fuel system. just dont want to take it apart and find out I need something I dont have..
easy question for most I know.....
Old Feb 4, 2007 | 10:37 AM
deadtrend1's Avatar
just spray it really well with penetraiting oil and let it soak in. I use two vice-grips to get it off. (wont hurt the nuts if your careful). put the new one on with the arrow going the right way. Nothing else needed ...
Old Feb 4, 2007 | 10:41 AM
dp149's Avatar
ok..thanks...so their are no o-rings to check or replace?
Old Mar 11, 2007 | 12:37 AM
Jetmeck's Avatar
Car: '89 GTA 9,000 MILES
Axle/Gears: 3.27 9 bolt
O-rings ?
Old Mar 11, 2007 | 01:41 AM
LoneStar666's Avatar
Car: 2005 Pontiac GTO
Engine: 364ci LS2
Transmission: 6 speed
Axle/Gears: 3.46
you need a 16mm, 20mm and 10mm wrench to change the fuel filter.... thats how it is on my camaro and im pretty sure its the same on the firebird.
Old Mar 11, 2007 | 03:51 AM
LAFireboyd's Avatar
Axle/Gears: 9-bolt/3.45
Yes, there are tiny o-rings on the ends of the fuel lines where they plug into the filter at each end. But unless you have a drip out of either end of the old filter, they should still be good. So no worries, it's very unlikely you'd have to replace them.
Old Mar 11, 2007 | 01:13 PM
Jetmeck's Avatar
For about a dollar I won't take a chance.
92camaroJoe
Jul 29, 2023 07:57 PM
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
