K+N filter on SD TB question?
Old Feb 8, 2007 | 05:26 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Those of you running a K+N filter direct on the TB in speed density apps , how do you go about getting clearance to plug in the TPS plug?
With the filter on the TB is less than 1/2 " between TPS (where the wiring plugs in ) and the rear of the filter
Old Feb 8, 2007 | 07:38 AM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
I used to have a K&N filter right on the throttle body and there was no clearance problems. I think the part number was a 5001?
Old Feb 8, 2007 | 04:26 PM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
I've got the RC5000 filter and clearance is fine.
Old Feb 8, 2007 | 08:39 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
That's the part #!
Old Feb 10, 2007 | 05:47 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
thanx for replys.
Can not find any # on the filter , bought of a Forum member less box.Appears identical to RC 5000.
Lip where hose clip mounts is only big enough for clip , not allowing enough room for plug.
See (dialup beware )
http://members.optusnet.com.au/~jesney1/gallery.html
Is worse on BBK on account of the TB lip being shorter than stock TB.
May have to fab a adapter to move filter further out to gain plug clearance.
Old Feb 10, 2007 | 08:19 PM
Boosted_SS's Avatar
Car: Cobalt SS/SC and 88 IROCZ
Engine: 383 TPI
Axle/Gears: 3.73 Eaton Posi
that is definately the part number and from the looks of it you have that filter. i'll look at mine next time i go to the garage where i have it in the winter and see what's differant.
Old Feb 10, 2007 | 10:20 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Is it like this?
I never had a problem.
Old Feb 11, 2007 | 03:50 PM
Andy 91GTA's Avatar
Car: 91 GTA & 92 GTA & 92 GTA
Engine: 305 TPI & 350 TPI & 350 TPI
Axle/Gears: 3.42 & 3.23 & 3.23
You should build your own CAI setup. Your sucking in all kinds of hot air by mounting the air filter to the TB.
Old Feb 15, 2007 | 05:12 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
I am of sorts.
Am being naughty and cutting hood of my Vette
( big no no in Vette world) to clear HSR on race 383
Have pro stock type forward facing scoop for HSR clearance and air intake so intend to form alum box under K&N so only draws cool outside air in.
Vette's are worse than F bodies when it comes to getting cool air in.
My street Vette , stock 350TPI w ZZ4 cam will run 12.9 in sub 75F temps,13.2 or worse if over 85F
Brinkkl2000
Aug 4, 2018 08:29 AM
69 Six Pack
Oct 5, 2015 07:51 PM
Thornburg
Aug 25, 2015 01:46 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
