Buring Oil and No Oil Pressure!!
Old Feb 12, 2007 | 04:50 PM
mytagta's Avatar
I have a 1989 Trans Am GTA, 5.7L 350, i have had the car for almost a year and it has been buring oil the whole time. Although, lately i have been getting very little oil pressure at idel.
I was wondering what could be the cause of this? is it valve guides, Valve Stem Seals, im am not sure. I have searched aroung but havent been able to find any help.
When i start the car up it will puff out blue smoke and occ. when i drive, if i am ideling for a while the car will have trouble building oil pressure and it will die if i put in in drive or reverse, it will sometimes die just in idel.
Im looking for an answer to help solve this problum.
Old Feb 12, 2007 | 10:22 PM
Boosted_SS's Avatar
Car: Cobalt SS/SC and 88 IROCZ
Engine: 383 TPI
Axle/Gears: 3.73 Eaton Posi
check the gauge. i had this problem with my 88 before my motor went and then again after i put the new motor in. i put a manual gauge on and i had 60psi.
Old Feb 13, 2007 | 09:21 AM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
The normal puff of smoke at start up is just your valve seals. I changed mine when I swapped my cam.
And I agree, put a different guage on there to see what it actually reads.
Maybe do a compression test on it.
83 Crossfire TA
Jan 3, 2016 01:26 PM
toronto formula
Nov 10, 2015 06:17 AM
angel2794
Sep 8, 2015 06:22 PM
Strick1
Sep 4, 2015 07:11 AM
