Valve lash
Old Feb 13, 2007 | 07:07 PM
1987ZTPI's Avatar
Car: 1987 IROC-Z
Engine: 310 lb9
Transmission: SEMI STOCK 700R4
Axle/Gears: 3.45 9 BOLT
Valve lash
I've got a 87 305 TPI roller motor and i wanna set valve lash people have told me to set it at 1/4 turn past zero lash and others have told me to set it at 3/4 turns isn't that to much pre-load on the lifters .
Old Feb 13, 2007 | 10:18 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
No its not. Factory is accually more then 1 full turn. Anything from 1/4 to 1 full turn is fine. But I personally run mine around 1/4.. I've done back to back tests on the dyno from 1/4 to 1 full turn. Power was the same along with top RPM. No differance.
Old Feb 14, 2007 | 01:13 AM
89Nighthawk's Avatar
Car: 89 GTA Nighthawk
Engine: 389 CID Vortec TPI
Transmission: TCI 700R4 w/Vigilante
The rule of thumb is 1/4 to 3/4 if you adjust cold, not running. If hot and running, back off until it clatters, tighten until the clattering stops and go another 1/2 turn. You want to preload the lifter but not bottom it out.
Old Feb 14, 2007 | 04:51 PM
1987ZTPI's Avatar
Car: 1987 IROC-Z
Engine: 310 lb9
whats the best or easyest way to do it i'm sure it takes longer to do it without the engine running but i don't want to do any damage to my engine by running it without prpoer vlave lash. and i can adjust from 1/4 to 3/4 turn after zero lash and it will operate correctly.
Old Feb 14, 2007 | 05:34 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
it is zero lash plus 1 full turn when warm, or about 3/4 turn when cold
this is to set the plungers to the center of their travel inside the lifters
this is for hydraulic lifters only of course
any true gm service manual shows this adjustment info
it has always been zero plus one full turn
go here and scroll down a little
http://www.centuryperformance.com/valveadjustment.asp
Old Feb 14, 2007 | 09:06 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
In a high performance book by a well known author, he states (if I remember correctly) 1/4 turn past zero lash. I have set my lash this way for the last 10 years. This is for hydraulic roller lifters with engines having good horsepower and revving higher than stock.
SPEEDY Z28
Brakes
16
Apr 18, 2016 02:46 PM
sleprock
Sep 24, 2015 04:33 PM
355tpipickup
Sep 13, 2015 11:35 PM
sandman92084
Sep 12, 2015 10:27 PM
dimented24x7
Sep 6, 2015 03:51 PM
