Best Cam?
Old Feb 14, 2007 | 05:02 PM
baroner's Avatar
Car: 87 trans am WS6
Best Cam?
Ive got an 87 lb9 automatic(basicly stock) and i was lookin to swap in a new cam. Im not really sure what one to go with to get the most torque, i heard a new cam could give anywear from 15-50 pounds of torque and over 30 horsepower. Can anybody give me some suggestions on the best models?
Old Feb 14, 2007 | 05:29 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
I used a comp xr258h-10r, it worked great.
Old Feb 14, 2007 | 05:45 PM
zz4monte's Avatar
Car: 87 Monte Carlo ss
Engine: ZZ4 1.5 rollers 650DP
Transmission: Probuilt 700-R4
Axle/Gears: 8.5 GN 3.42
LB9GTA has got it right.The xr258hr-10 is a good cam for a slightly modded 305 if you want a lobe seperation of 110. Another good choice would be a 208-212 duration Hyd. roller cam with a 112 lobe seperation and a similar amount of lift, here are some examples.
Comp cams
XR258-10 206 212 Dur. 480 487 Lift 110 lobe sep.
comp computer controlled cam (called something different now) 210 220 Dur. 480 480 lift 112 lobe sep.
ZZ4-cam 208 221 Dur. 474 510 lift 112 lobe sep.
Lingenfilter 211 219 dur. 503 525 lift 112 lobe sep
All of these would work well in a LB9. I hope you have headers and non-stock exhaust? Those are more important for power then a cam swap but these are the types of cams you want if you want a modest increase in power and still drive it everyday. The best cam for "torque" would be the XR258-10 for sure with its 110 lobe seperation, plus this cam has alot more overlap then the 112 lope. seperation cams.
Old Feb 14, 2007 | 09:11 PM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
in my 87......the cam is in my sig. I'm VERY happy with it!
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
