warm tpi.....super lame
Old Feb 13, 2007 | 10:22 PM
seymourless's Avatar
my car now dies unless i have the gas pressed when its warm for like 10 or so mins.i thought i had fixed the problem yesterday, to find a plug going to a fuel injector was loose, that wasn't it. it will run fine when cold but once warm, you can gradually see the drop of rpms as soon as i let off the gas. it will get worse and worse until the point of me letting of the gas and it dieing instantly. also a code 36 appears randomly sometimes, yet i have a new maf and all new ignition. i checked the fuel pressure, and its fine so the fuel pump is good. i also have a new fuel filter in. my prediction is that i have a bad/dirty injector(s), or some crazy case of vapor lock. am i right? i used an auto stethoscope to listen to the injectors but all seemed ok(what the book said). I also checked the resistance of each injector, and all were about 16.7 (books says between 11 and 14 i think) any help would be greatly appreciated, for it sucks driving with a foot on the gas and another on the brake (for now i only drive it 5 miles to school a day).
thanks
Old Feb 13, 2007 | 11:13 PM
Boosted_SS's Avatar
Car: Cobalt SS/SC and 88 IROCZ
Engine: 383 TPI
Axle/Gears: 3.73 Eaton Posi
did you try checking the voltage to the idle air controller?
Old Feb 14, 2007 | 03:34 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
what is the code 36 ?
Old Feb 14, 2007 | 09:30 PM
LoneStar666's Avatar
Car: 2005 Pontiac GTO
Engine: 364ci LS2
Transmission: 6 speed
Axle/Gears: 3.46
could be a vacuum leak that gets worse as the motor warms up
Old Feb 15, 2007 | 10:56 AM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
I had a split hose going to the T/B that made the car not idle at all. Had a mushy feal to the throttle aswell
Old Feb 15, 2007 | 12:01 PM
code 36 is maf sensor burn off circuit. poor electrical connection, open or short in circuit, defective esc module, defective knock sensor, defctive ecm. i have also had a code 35 before which is idle speed control. this states tps sticking or mis adjusted, poor connection, defective iac valve, defective ecm. i have a good feeling it is the iac valve. is it the thing under the throttle body on the left, under that tps?
Old Feb 15, 2007 | 12:51 PM
ok i haver the iac sensor out, its covered with carbon and stuff. how do i test if it is bad or not? i think i read that u should be able to easily push it in, mine does not budge. any extra help would be greatly appreciated.
thanks
Old Feb 15, 2007 | 01:46 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
Most likely it's a bad Maf burnoff relay gone bad.
Old Feb 15, 2007 | 02:47 PM
is that part of the maf sensor itself or wiring further back?, cause i payed 200 bucks for a new maf sensor like 3 months ago
Old Feb 15, 2007 | 04:01 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
It's mounted on the firewall near the master cylinder. It costs about $10.00. I'm attaching a picture that someone took for me when I had your problem.
Good Luck
Old Feb 15, 2007 | 05:02 PM
thank you very much guys, i really appreciate all of your help. i just bought a new iac and it seems to be driving ok, but i have a feeling it will act up tomm, so i will def use all of your input to try and find a problem.
Old Feb 16, 2007 | 11:06 AM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
you know you have to reset the minimum idle air right ? it's just getting it all buttoned up that will make the differance.
Old Mar 2, 2007 | 10:23 PM
mckenzie's Avatar
what kind of reading are you getting from your o2 sensor? your car runs off a fixed value until the o2 sensor warms to temp. take a close look at your o2 sensor.
tyeo098
Nov 30, 2015 06:27 PM
HoosierinWA
Oct 7, 2015 10:15 AM
thejimsterz28
Sep 30, 2015 08:52 PM
mfp189
Sep 27, 2015 09:25 AM
amcnellis
Sep 16, 2015 04:16 PM
