350 ca smog legal intake
Old Feb 13, 2007 | 10:36 PM
raiders8498's Avatar
Car: 88 Trans Am
I have a 350 block to replace my 305, but my problem is that i dont know what intake to use to allow the flow i need. im ganna try to hit 400-430hp i heared tpi doesnt flow good, so what are you guys using to make the power and keep it legal, then on the other had im considering an ls1 engine, and its more expensive but im comfused im just looking for imput thanks.
Old Feb 13, 2007 | 11:14 PM
Boosted_SS's Avatar
Car: Cobalt SS/SC and 88 IROCZ
Engine: 383 TPI
Axle/Gears: 3.73 Eaton Posi
accell super ram
Old Feb 14, 2007 | 12:48 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Correct. The Accel Super Ram is the only smog-legal aftermarket intake. It consists of an Edelbrock base and a specific set of runners mated to a large plenum. You could also get an Edelbrock base and a set of AS&M semi-siamese runners and reuse your stock plenum.
Old Feb 14, 2007 | 09:00 PM
Car: 88 Trans Am
what about slp or is accel better
Old Feb 15, 2007 | 01:19 AM
Kevin91Z's Avatar
SLP runners are the smallest, but you can port them bigger and better. The SuperRam is the best smog-legal intake out there. The others are just bigger diameter runners but the same length. Its the length that limits the horsepower.
Old Feb 15, 2007 | 09:59 PM
Car: 88 Trans Am
well looks like ill go with accel thanks
Jake_92RS
Jan 28, 2020 10:37 PM
onefreakz
May 14, 2018 12:15 PM
Burnt.Clutch
Camaros Wanted
Aug 21, 2015 11:11 PM
camaro_rs350
Northern California
Aug 18, 2015 12:38 AM
st.evel07
Aug 13, 2015 06:15 PM
