Visual TPI intake manifold ports
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
The base I have for testing is just that and will never see a car again. So posting pictures of it might steer some people in a bad direction from past test fittings. I have more intakes to weld up and will post pictures then.
My ported base was 290 cfm @ 28" and I think that good for a first prototype port. I think 300 to 310 can be a reality
Jerry
Jerry
So which intake flowed over 300 cfm?
Car: 2003 Porsche C4S
Engine: 3.6L
Transmission: 6-speed Manual
Jerry
The thermostat housing will be changed after I get some time to fab something that clears the dual inlet air filter system I have.Jerry
The port on the left was ported to the injector o-ring. That will get you a 1.875 tall port and will flow in the low 290s. The next thing to try is making a new injector bung and weld it in, this will let me move the roof up more and give it room for a 2.025 tall port.
Jerry
The port on the right is .250 up and flowed 290. The one on the left is rough milled to show how much is removed to get 1.875 tall. With the injector bung relocate I hope to get .150 more.
Jerry
Jerry
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
I have seen the worked Jerry has done on the port. I might mention what does not easily show up in the photo is that he has changed the port angle in the roof to more closely match the angle into the head. A big improvement. What Jerry has done is a major improvement over the Edelbrock design.
Engine: 3.6L
Jerry,
What are you going to do about the fuel rails with the revised fuel injector geometry? Are you going to modify the stock fuel rails to work or go aftermarket?
Car: 1989 GTA
Engine: 369 TPI
I would guess that he is going to raise the fuel rail with spacers. If he needs to narrow the rails that is not a big deal. I have to do that when I adapt the GM fuel rail assembly to the First intake. Just have to make shorter cross over tubes. He may not have to make them narrower. There may be enough play as is.
The stock fuel rails will still work, I moved the injectors and rails up .250. Not on the center line of the injector but still at the factory 26 degree angle. To do this the new injector bung is bored .109 offset to outside of the factory injector centerline and then you will still have everything at the factory angle. The super ram has over .375 from the plenum to the fuel rails and if needed I will use button head bolts or countersink them to hold the fuel rails down.
Right now the welded intake has a minimum area of 2.23 sq in. that is up from a stock Edelbrock TPI at 1.74 sq in. I hope with the injector relocation I can get to 2.54 sq in. and then the runner to base interface will start to be a problem.
FYI
Stock Edelbrock TPI--1.74
My welded TPI-------2.23
Victor 2 bbl----------2.60
Victor---------------2.80
Victor Jr.------------3.00
Super Victor---------3.20
Billy G. Victor--------3.80
Car: '89 Formula 350
Engine: 5.7L L98 TPI
Transmission: 700-R4 Automatic
Axle/Gears: 7.5 disc posi 3.23
WOW,
This is a super technical thread. You guys are really cutting edge TPI pioneers.
I hope to see an article with some step by steps. That would be a keeper!!
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
Re: Visual TPI intake manifold ports
first time checking this out. Once you guys get it all nailed down for a 300CFM edelbrock tpi base and runners. Will you guys be takeing any jobs on the get these done for others . I would be interested in it with the new turbo setup ... any and all improvements are welcome .
congrats ... screw all the tpi haters
Car: 90 IROC
Engine: 406
Car: '88 Camaro
Engine: 5.7 L98
Axle/Gears: Borg Warner 9 bolt w/3.27 lim. slip
Any news? Looking FWD to hearing about this. I plan on keeping the TPI in my IROC when I do the 383 and have plans for a TPI in my '54 Chevy truck.
Car: 90 IROC
Engine: 406
Hey Daniel! Hows it going? The Truck is looking awesome! Its really come along way sence the last time i seen it. Should be a blast to drive with a TPI sb.
Hang in there it will be worth all the work and money when its done.
Is the modified base a stock or edlebrock base?
Do the original pictures from the beginning of the thread still exist? I’d bet that with respect to actual performance on a running engine you’d get more from fixing the port entry angle than just a raw increase in flow since with the stock entry angle I would be surprised if there wasn’t some flow separation on the port floor in the head.
Car: 1989 GTA
Engine: 369 TPI
Edelbrock base. You are correct in that the port angle entry to the head is not the best. The modification is killing two birds with one stone so to speak. Help correct the port angle entry into the head and also open up the cross section area to match the head port.
You don't want the runner to have less of a cross sectional area than the head you are using. In other words you don't want the intake manifold or anything else for that matter upstream of the head to be a restriction on the head. Then again you don't want it to big as then you will have lazy air flow.
Car: 88IROC, 91Z28 + parts cars
Engine: 355, 408
Axle/Gears: 3.42 LS1, 9" w/ 4.56 and spool
Noticed this thread has been going for quite some time. Is there any chance on seeing the flow numbers for the various manifolds. I would be very interested as the intake is the next piece of the puzzle I need for my current project
Car: 1989 GTA
Engine: 369 TPI
The owners of the intake manifolds have not posted their actual results. So I will respect that. However it has been posted that they flowed over 300cfm.
IMHO opinion the big problem is not the intake manifold as that can be dealt with by the methods shown in this post. It is the runners where the bottle neck is on a TPI unit.
Car: '88 Camaro
Engine: 5.7 L98
It's coming along. All things in time. I'll PM you when I get some new pics or you can follow the link in my sig
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Yahoo changed servers on me, so here are the pics on Flickr.
http://www.flickr.com/photos/1864480...7602977289102/
My manifold flowed 260 after original porting, and 310 after this welding and porting mod. There is a magazine article on this site that I posted that gives the flow specs of an Accel manifold with runners. See the magazine section from the main page of thirdgen.org.
Uhm... the whole sticky thread "Our quest for a better flowing TPI" at the top of this TPI forum is our dyno results.
No track time yet with the siamesed runners. I used the long tube runners at Fontana back in May, and I was so out of practice I couldnt launch without bogging. Best time was a 13.23 @ 104 or so.
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
The last post was in 11-07-2008. Im sure that there has been some testing since then. so, are there any results?
Yes, the results are in the "Quest for a better flowing TPI" sticky thread at the top of the TPI forum.
Aahh damn. DUHH! Thanks Kevin91Z. I forgot that this was a separate thread. Ill check out the thread mentioned.
ambainb
Apr 25, 2016 09:21 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
