89 plenum on 88 car
89 plenum on 88 car
I have just purchased a plenum without the small passage between the 2 throttlebody holes. I also have non cold start SLP runners i wanted to install with this. The problem is that i have an 88 throttle body with IAC, will this plenum work?
Car: 1987 IROC 1991 RS
Engine: 5.7 TPI 5.0 TBI
Transmission: T-5 , 700R4
Axle/Gears: 2.73 twice
The 9th injector already gets all the air it needs. The IAC uses this passage to keep the motor idling, no air, no idle. Otherwise use the ******* idea of a brick.
Linson
Aug 21, 2015 02:12 PM
