Which car needs 6AL more?
Old Feb 19, 2007 | 06:32 PM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
Ok, long story "shortened".
I installed an MSD 6A in my Formula. I already have one in my Nova. I bought another one off of a friend to use in my fiance's Civic, and it turned out to be a 6AL.
First off the Civic is hers, and it's only for gas miliage purposes, not racing. (1.5L VTEC-E)
Second, I was thinking of puting the 6AL in the Formula for rev limiting reasons, and use the new 6A for the Civic. The Civic has a rev limiter in the ECM. Does the Formula also have a rev limiter? ('88 L98)
Third, if the Formula has a rev limiter stock, I'll put the 6AL in the Nova (which is carburated and has no limiter), and put the old 6A in the Civic.
Either way she gets the 6A, and one of my cars gets the 6AL.
Thoughts?
Old Feb 19, 2007 | 06:54 PM
79malbiu's Avatar
put the 6A in the bird
put the 6AL in the nova
I have a 6A in my civic & you cant just install it it will burn the factory coil out within a week if you do you'll have to buy a MSD distributor cap & blaster 2 coil
Old Apr 15, 2007 | 09:12 PM
MattODoom's Avatar
Car: '88 G T/A
Axle/Gears: 3.27 9 Bolt
Re: Which car needs 6AL more?
My 88 L98 had a rev limiter in the ECM. Stock it was set at over 10k RPM's though, LOL. But you can change it...
Old Apr 15, 2007 | 09:34 PM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
i'd hate to know how you figured that out.. i hope it wasnt trial and error
edit: 6AL in the nova
Old Apr 16, 2007 | 11:02 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Just make sure you wire it so you can disable it when it goes bad...they all do. LOL
Old Apr 22, 2007 | 10:44 PM
stingerssx's Avatar
I've had the same MSD 6A in 4 cars in the past 10 years with great results. Never gone bad.
Looks like I'm gonna put the AL in the Nova, and I already put a 6A in the bird. After I switch the 6A for the 6AL, I'll put the 6A in the Civic.
Thanks all!!
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
