It wouldn't start
Old Feb 19, 2007 | 07:17 PM
b1gdadde1234's Avatar
It wouldn't start
I got the car to turn over now but we put a new fuel filter on the car but that helped a little. We still can't get it to start the fuel pump is turning on but the fuel is barely coming out of the tpi. We have to start it with starting fluid but it won't stay running.
b1gdadde1234
Old Feb 21, 2007 | 08:34 PM
joejoe's Avatar
Car: red one
Engine: on the floor
Transmission: next to engine
Axle/Gears: the ones that turn
Your fuel pres. should be around 43.5 PSI, if not, the pump may be bad. Will it stay runing if keep spraying carb cleaner in the TB?
Old Feb 21, 2007 | 08:51 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
What is the fuel pressure?
The first thing to check on a non-starting EFI car is the fuel pressure! Every mechanic will tell you that.
Old Feb 22, 2007 | 07:38 AM
yes it will keep runnig if I spraying it with carb cleaner the fuel pump is turning on.
Old Feb 22, 2007 | 08:10 PM
joejoe's Avatar
Car: red one
Check the fuel pres. let us know what the pres. is, it sounds like the pump.
The pump can be runing and not generate the presure needed to run the motor.
Street Lethal
Apr 30, 2019 12:14 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
