Haveing trouble with MAF sensor.
Old Feb 20, 2007 | 06:47 AM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
I just got my car a few weeks ago, and when i bought it the mass air flow sensor was bad. I replaced it and now after the car sits over night, the battery is dead the next morning. The battery is brand new, i replaced it as well. I did a search on here and came across a similar situation, said that if the relay for the MAF was bad that it would cause the MAF to run constantly causing the battery to die. IF this is the case, which relay is for the MAF?? And also, how can i tell if i fried my new MAF sensor??
Old Feb 20, 2007 | 11:32 AM
Vader's Avatar
Either relay beign energized constantly (or having contacts stuck) can drain the battery, although the burn-off relay would do it faster. You can either:
  1. Meter through the contacts to determine if they are stuck or arcedl
  2. Remove, open, and inspect the relays;
  3. Or replace the burn-off relay. If the problem still occurs after replacing the burn-off, use the old relay to replace the MAF power relay.
There is also the possibility that the output transistor in the ECM has an E-C short and is keeping a relay energized constantly, or that the wire harness has problems, and is doing the same thing. I'd start with the relays themselves, since they are the most likely candidates for "Troublemaker of the Week" and are the easiest.
Old Feb 20, 2007 | 08:04 PM
Boosted_SS's Avatar
Car: Cobalt SS/SC and 88 IROCZ
Engine: 383 TPI
Axle/Gears: 3.73 Eaton Posi
well to narrow it down to the MAF when you shut the car off for the night just unplug the MAF and see if it starts the next day. if it starts you know it's the MAF and if it doesn't then you know know it's something else.
Old Feb 21, 2007 | 09:38 AM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
Yea, i have already narrowed it down to that, i just unplugged it all together and now its starts fine of the mornings
bryan623
Mar 22, 2021 06:43 PM
NBrehm
Aug 25, 2015 11:49 PM
hokis
Aug 9, 2015 03:57 PM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
