what is the best fuel pump regulator????
Old Feb 20, 2007 | 07:50 PM
patgta's Avatar
Who makes the best fuel pump regulator? (for performance and user friendly for adjusting)
-BBK
-Holley
-Crane
-Jet
-Accel
or any other ones??
Pat
Old Feb 20, 2007 | 09:48 PM
brians88gta's Avatar
Car: 88 gta
Engine: 350 HSR
Axle/Gears: 3:27 borg warner 9 bolt
i just got the bbk the scew is about half inch 2 long so u have to pullthe pletun every time u want 2 adjust
Old Feb 20, 2007 | 11:05 PM
Enyce31082's Avatar
Car: 1987 Pontiac Trans Am
i also went with BBK with that part.
Old Feb 20, 2007 | 11:29 PM
anthony64ss's Avatar
Car: 1984 Z28
Engine: L31
Transmission: WC T5
Axle/Gears: 10 bolt 3.73
A couple more:
-Mallory
-TPIS
-Ebay
They all do the same thing. Holley has a **** for adjustment, not a screw, which makes it supposedly easier to adjust. Everyone has had problems with every single one at one time or another. Just get the one that costs less.
Old Feb 21, 2007 | 07:59 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
I'm on my third Holley in a row. All have been bad including the one that's on my car now. I'll be sending this one back as well. I like the **** adjustment but after 3 regulators I think i'm going to go Aeromotive unless Holley themselves will give me one that actually works correctly.
Old Feb 21, 2007 | 08:42 AM
90CamaroTBI's Avatar
Car: 91 Formula, 89 IROC
Engine: LB9, LB9
Transmission: 700R4, 700R4
Axle/Gears: Posi 2.73, Posi 2.73
I was thinking about going with the crane one.
Old Feb 21, 2007 | 09:08 AM
Lucky7's Avatar
Car: 86 Vette
Engine: 383 TPI
Transmission: Richmond 6 Spd.
Hey Vperklr, what goes bad on the Holley? I'm curious because I'm getting ready to put one on my car.... W/SR it'll be a B****h to redue!
Old Feb 21, 2007 | 09:21 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
With mine none of them would go above 30psi and they all leaked down within 5 minutes. I put a quarter on top of the spring inside the regulator and now I get plenty of pressure but it still leaks down too fast. My pump is fine and so are my injectors. Aside from the tests I've run to prove this, whenever I put my stock regulator back on I have none of these problems.
Old Feb 21, 2007 | 09:31 AM
Lucky7's Avatar
Car: 86 Vette
Engine: 383 TPI
How much is the Aeromotive? Where are you going to purchase it?
I'm already sending back a valve spring tester to Summit, might as well rid myself of the regulator at the same time!
Sounds as if the springs are weak on the Holley...
Old Feb 21, 2007 | 09:37 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Haven't figured out where yet. My engine is strewn between my garage, spare bedroom, basement, New Jersey, Michigan, South Carolina, you get the point.
I personally believe the shaft on the adjustment wheel is too short. Putting in the quarter proves that. I still don't know why the thing leaks down though.
Old Feb 21, 2007 | 09:43 AM
Lucky7's Avatar
Car: 86 Vette
Engine: 383 TPI
Mine's been like that for 3 yrs! Wife finally got pissed! That got things going in a hurry! I just cced the heads last night, and am going to assemble this week. + she said if I get it running, and sold I can buy a newer Vette (this one's an 86).
92camaroJoe
Jul 29, 2023 07:57 PM
9192camaro
16
Feb 3, 2019 12:21 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
