Injector Size calculator - check it out
Old Feb 20, 2007 | 07:55 PM
Boosted_SS's Avatar
Car: Cobalt SS/SC and 88 IROCZ
Engine: 383 TPI
Axle/Gears: 3.73 Eaton Posi
thought this might be helpful for those of you are trying to figure out what size injectors to use.
click the link~~~> http://www.injector.com/injectorselection.php
Old Feb 21, 2007 | 07:50 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Cool.
I hope it's wrong though. According to the calc i'm going to need bigger injectors than my 26lb to support my engine.
Old Feb 21, 2007 | 08:02 AM
Lucky7's Avatar
Car: 86 Vette
Engine: 383 TPI
Transmission: Richmond 6 Spd.
I often wonder how accurate these are, I see a lot of guys over at Corvette Forum running FMS # 24 injectors. Some of these guys are running 10's.
This calculator says that I need 32's, but I'm thinking she'll idle snotty rich. Maybe I'm wrong (I often am!) but the # 24s seem to be what I want. I've got # 30s too so if the # 24s go lean I'll just swap.
Old Feb 21, 2007 | 09:30 PM
Boosted_SS's Avatar
Engine: 383 TPI
well as i've been told the stock injectors barely flow enough for a 305 let alone a 350. and with the 24#'s that's just barely a step above stock and you have a 383. plus if you get a chip burned and program the chip for the bigger injectors it will actually make the injectors last longer since they aren't working as hard (the duty cycle). as i understand it the duty cycle is the amount of time the injectors are firing so the less they are actually working the better IMO.
Old Feb 21, 2007 | 09:48 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
You need to know the BSFC for your motor. If stock .5 is probably OK. Also that is based on 43.5 pounds of fuel pressure. With more fuel pressure you need less injector.
Old Feb 22, 2007 | 07:32 AM
Lucky7's Avatar
Car: 86 Vette
Engine: 383 TPI
When they flow the Ford injectors, they use 39 psi. At 43.5, it;s already at # 26. When you hit 47 you're at about 28. Jesse (Ski Down It) a tuner over at Corvette Forum was using # 24 Fords in his low 10 sec. vette. But then Alvin another tuner at PCM for less usually says 30s. I could be wrong about all this, but I just hate the thought of taking apart the Superam twice.
Old Feb 24, 2007 | 01:12 AM
89Nighthawk's Avatar
Car: 89 GTA Nighthawk
Engine: 389 CID Vortec TPI
Transmission: TCI 700R4 w/Vigilante
This calculation doesn't account for different injector firing systems. TPI's are batch fire, so they need a lot less injector for the same power as would a Sequential system that only fires the individual injector.
toronto formula
Nov 10, 2015 06:17 AM
69 Six Pack
Oct 5, 2015 07:51 PM
Red iroc-z 305
Sep 30, 2015 05:22 PM
bamaboy0323
Sep 3, 2015 06:07 AM
knight72
Aug 10, 2015 09:32 PM
