Max lift with stock valve covers
Old Feb 21, 2007 | 09:33 PM
79malbiu's Avatar
what is the highest lift that the centerbolt valve cover can accept im using crane gold 1.6 roller rockers lift is .500
Old Feb 21, 2007 | 09:51 PM
Boosted_SS's Avatar
Car: Cobalt SS/SC and 88 IROCZ
Engine: 383 TPI
Axle/Gears: 3.73 Eaton Posi
are you using the stock heads is the first question...
are you sure the rockers are compatible with center bolt valve covers is the second question...
Old Feb 21, 2007 | 10:50 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
The valve overs will easily handle the .500 lift. I ran .535" lift with no problems. I'm sure they can handle even more lift.
Old Feb 22, 2007 | 09:34 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
I have never heard that the valve covers interfer with valve lift,,, however, the size of the rockers do interfer with the metal baffles inside the valve covers. I had to cut out a few of these baffles. I did this 10 years ago, to I cant give you any details, but its easy to figure out what needs trimming.
Old Feb 23, 2007 | 05:43 PM
79malbiu's Avatar
yeah everything is stock
NBrehm
Aug 25, 2015 11:49 PM
db057
Aug 22, 2015 08:17 PM
blackd-out z28
Aug 15, 2015 08:18 PM
Street Lethal
Aug 12, 2015 11:33 AM
mustangman65_79
Aug 8, 2015 01:18 AM
