305 heads on a 350
Old Feb 22, 2007 | 03:22 PM
jaysfs's Avatar
Car: 91 z28, 07 trailblazer ss
Engine: lt1lt4 hot cam,ls2
Transmission: t56
305 heads on a 350
i have a 89 tpi motor and was wandering if using 305 tpi heads would do me any good or just stick with the ones i have
Old Feb 22, 2007 | 03:43 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Ah. The poor man's way of raising compression.
Old Feb 22, 2007 | 06:30 PM
jaysfs's Avatar
Transmission: t56
not the answer i was looking for,and yes i am broke
Old Feb 22, 2007 | 06:44 PM
Boosted_SS's Avatar
Car: Cobalt SS/SC and 88 IROCZ
Engine: 383 TPI
Axle/Gears: 3.73 Eaton Posi
it would raise compression and it would then cause you to have to use higher octane fuel. personally i would stick with what you have with the price of gas now a days
Old Feb 23, 2007 | 07:07 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Do you have access to a datalogging tool? You'd only need higher octane gas with the 305 heads if you start detonating.
Old schoolers used to throw 305 heads on 350's all the time.
Detonation is the only thing you'd have to worry about. Maybe you could retard your timing a bit to help alleviate that worry.
Old Feb 23, 2007 | 08:00 AM
Boosted_SS's Avatar
Engine: 383 TPI
yes but that would offset the advantages of raising the compression
Old Feb 23, 2007 | 10:23 AM
jaysfs's Avatar
Transmission: t56
ah that idea just died.i found a set of vortec heads for 200 with no miles. thanks for the help
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
gta90
Sep 15, 2015 04:00 PM
NinjaNife
Aug 23, 2015 11:49 AM
st.evel07
Aug 13, 2015 06:15 PM
