l98 heads
Old Mar 5, 2007 | 07:13 PM
gta87ls1's Avatar
Car: 1987 Pontiac GTA
Engine: 350tpi
Transmission: t56 6 speed
Axle/Gears: 3.70
l98 heads
Does anyone know where I can get the l-98 heads that will fit my 350 from a 1992 camaro. I looked everywhere and can't seem to find any anywhere. I bought the engine assuming it had everything it should and come to find out it has the 14102193 heads on it instead of the 14101083.
Old Mar 5, 2007 | 08:11 PM
Dans87GTA's Avatar
Car: 1987 Pontiac Trans Am GTA
Engine: 355 Stealth Ram
Transmission: 700R4 w/ 2600 stall
Axle/Gears: 9-bolt 3.27
Well i dont know how much of a rush you are in but i have a set on my car that some time soon should be coming off to put on a set of vortec's. there are not stock they have minor porting work and a competition 3 angle valve job dont to them. On my current set-up i have gone 13.2@102 so far. let me know i can get them taken off faster if i know someone wants to buy them. Later Daniel
Old Mar 6, 2007 | 12:38 AM
89Nighthawk's Avatar
Car: 89 GTA Nighthawk
Engine: 389 CID Vortec TPI
Transmission: TCI 700R4 w/Vigilante
Have you tried TPI parts and Hawks?
Old Mar 6, 2007 | 08:02 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
I have a set of 083 heads ready to ship. mild porting. Should be rebuilt though.
Old Mar 6, 2007 | 05:50 PM
gta87ls1's Avatar
Engine: 350tpi
Axle/Gears: 3.70
how much are u guys looking to get for them?
Old Mar 7, 2007 | 06:15 PM
camarodarrell's Avatar
I have a set of these heads from my 1991 z28 350. Completely stock, should probably rebuild them. I will let them go for pretty cheap. Where are you located?
Old Mar 7, 2007 | 07:53 PM
Dans87GTA's Avatar
ill let my go for 250 plus shipping? just let me know! Later Daniel
Old Mar 7, 2007 | 08:25 PM
gta87ls1's Avatar
Engine: 350tpi
Axle/Gears: 3.70
I am located in rhode island. Curious as to how you guys usually handle paying online all i use is paypal thats all I know how to use
Old Mar 8, 2007 | 07:41 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Sent you a PM.
Old Mar 8, 2007 | 05:25 PM
gta87ls1's Avatar
Engine: 350tpi
Axle/Gears: 3.70
nevermind guys i found some. I got them from clearwater cylinder head. They finally had a pair. Thanks anyway
Old Mar 8, 2007 | 06:38 PM
crazy85iroc's Avatar
hey guys I am kinda new to buying this kinda stuff for my camaro. I have a 1985 camaro tpi. I Had a 350 from an 88 camaro swapped into it. I know have an HSR installed, holley wet nos, holley 58mm tb, 42lb injectors, billet distributor, headers, catback, and a zz4 cam. I am almost done with my twin turbo system and after doing a lot of research I reliszed my compression is way to high. So I am looking for 76cc heads. Since I already have my HSR on the car I want to buy heads that will fit the Base manifold on the HSR. Do any heads fit? Do I need Vortec Heads? Do they make a 76cc vortec Head? And if worst comes to worst I will buy a sbc HSR and sell my Vortec HSR, but i really dont wanna do that. Any Info would be great. I was looking to get these heads:
http://www.midwestmotorsportsinc.com...PHEAD&line=MWM
lt500r55
Sep 1, 2021 01:30 PM
CRFred
Feb 7, 2016 11:39 PM
italiano67
Aug 31, 2015 06:04 PM
TheExaminer
Aug 19, 2015 10:07 PM
anesthes
Aug 8, 2015 09:37 PM
