9th injector ??
Old Mar 5, 2007 | 08:46 PM
avengersteve's Avatar
Car: 1988 firbird formula
Engine: 5.7l pony eater
Axle/Gears: 4.10
9th injector ??
i was wondering the pros and cons of deleting it...
can i just pull it out and plug the hole?
Old Mar 5, 2007 | 09:42 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
If you're car starts and runs fine then why bother?
Old Mar 5, 2007 | 09:54 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
U need it when it gets cold.
It is there for a reason.
I would convert to the 89 MAF code which is the latest revision anyhow ands doesnt use a cold start injector. Then I would remove it and plug it.
later
Jeremy
Old Mar 6, 2007 | 08:05 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
I pulled mine. Plugged it. And changed the startup fueling tables. Starts with just a flip of the key regardless of weather now. Gotta love prom crap.
Old Mar 11, 2007 | 01:49 PM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
is there a step by step method of how to do this correctly?
Old Mar 11, 2007 | 06:56 PM
TPI's Avatar
Car: '89 Trans AM/'88 GTA
Engine: (2) Tuned Port L98's
Back to what 3.8TransAM & firebirdjosh said,
I had to rebuild my L98 after it detonated,
I used some parts off a 1988 Trans AM
GTA, Including a cold-start intake manifold
and fuel rail.
Although my '89 car doesnt require
the cold-start injector, I still ran the
9th Injector, because I didnt have a
block-off plate at the time for the intake
manifold, and it looks clean ..It basically
stops a humongous vacuum leak.
The "dud" 9th Injector doesnt seem to
hinder performance in any way I can think
of, It also doesnt mess with my start-up,
for my '89 car isnt programmed for it.
Im with Josh, Itd be more of a waste
of time, then a favor. You'd do yourself
a favor by converting like 3.8 said.. then
if you wanted to remove the injector, then
by all means do so.. Just dont look for any
performance gain or the like..
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
ronchic
Mid-Atlantic Region
Sep 15, 2015 08:04 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
