383 hsr combo questions
Old Mar 9, 2007 | 08:23 AM
djr_678's Avatar
Car: 98 T/A 94 dodge ram
Engine: LS1/ 5.9
Im new to the TPI world i just picked up an 85 Z with a tired lb9 that has some blow by, im switching to a 87 harness and a 165 ecm. I'm going to build a 383, stealth ram with 30lb injectors, a set of edelbrock performer rpm heads, and a hyd roller around 220-230 duration with around .550 lift with a 112-114LSA my questions are
1. Does any one make a larger MAF or a way to upgrade the housing cause that looks like its gonna be a bit of restriction.
2. I really want to stay away from longtubes due to the ground clearance problems I dont want to be the guy that everybody looks are while draggin my expensive *** exhaust over a speed bump-(learned that on my 98 TA) would the edelbrock tes headers w/3" y-pipe that are on the car choke that kind of power, if they would be a huge restriction what would you recommend. I know its a compromise when using shorties but i want a driver that will go anywhere without worry.
3.Never ran a 383 before i heard due to increase in displacement you can run a larger cam and it doesnt affect drivability as much, brings me to this question on 355 with the above cam i would use a stall between 2800-3200 so would you go with a lower stall like 2200-2500?
4.an easy one-who does good custom chips
TIA
dave
Old Mar 9, 2007 | 09:10 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
TIA
dave
Dont swap to the 165, instead repin to a '730 and go speed density.
I don't know how much cam you plan on putting in that TPI setup, but anything over 224/230 degrees is gonna not work so well with TPI. I'd go with an 1800 with a cam like that.
-- Joe
Old Mar 9, 2007 | 10:45 AM
V8Rumble's Avatar
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
In addition to the info above, I'd go with either Hooker or SLP headers instead of the TES units.
Old Mar 10, 2007 | 12:10 AM
YenkoST's Avatar
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
Definately go with the 730ecm and speed density. For the StealthRam, a member laided down 341 rwhp with a 383, trickflow heads, and 224/230 cam.
Old Mar 10, 2007 | 12:23 AM
89formula350b2l's Avatar
Car: 92 Camaro
Engine: Dart SHP 406 HSR, LE heads
Transmission: Performabuilt Level 2, Vig 3200
Axle/Gears: S60 373
im actually waiting for my engine to be done 383 hsr motor specs in sig
IMissMy86TA
Aug 31, 2015 08:40 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
355tpipickup
Aug 22, 2015 06:06 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
