What Roller Rockers to get?
Old Mar 15, 2007 | 08:48 AM
wgripp's Avatar
Car: 1991 Trans Am GTA
Engine: L98(5.7 L TPI)
Transmission: 700r4(A4)
Axle/Gears: G80 RPO, 3:23s, Auburn Racer's Diff
I'm interested in upgrading to roller rockers in my virtually stock L98. (see mods in my signature)
What size, brand, and model should I get? I heard 1.6 is great. Any other options?
What supplier should I order the part from?
Are there any cons to this upgrade?
(Yes, I have searched)
Thanks!
Bill
Old Mar 16, 2007 | 11:20 PM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Summit makes narrow body 1.6 roller rockers to fit the center bolt heads. They look just like Crane rockers except they're blue. Decent price too.
Old Mar 17, 2007 | 12:55 AM
wgripp's Avatar
do you kno if they are full rollers?
Old Mar 17, 2007 | 01:48 AM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Engine: 305 TBI, 350 TPI
Transmission: 700R4 Both Cars
Axle/Gears: 3.23 Posi.. 4 wheel disc both cars
Yes, im interested also......Thanks....Tom
Old Mar 17, 2007 | 02:51 AM
BadSS's Avatar
These are the least expensive narrow body full rollers I know of at $159 and shipping.
http://www.cnc-motorsports.com/produ...98&CtgID=14982
On a stock engine with stock cam,,, you would see very little if any difference in power over the heat-treated long slots at $65
http://www.competitionproducts.com/p...sp?number=6160
Old Mar 17, 2007 | 07:39 AM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Badss, you do mean 1.6 compared to 1.6, right?????????????
Old Mar 17, 2007 | 08:26 AM
86camaro383's Avatar
Car: 86 Iroc
Engine: 383
Transmission: TH350
Axle/Gears: 3:73s!
With roller rockers, You get what you pay for.
On my 383, I have Comp Cam pro-magnums. $260. I have 1.5's because my cam is kinda....Big. On a stock cam 1.6s will be alright.
Old Mar 17, 2007 | 04:55 PM
Car: 1989 GTA
Originally Posted by wgripp
do you know if they are full rollers?
Yes they are. They're available in self aligning or non self aligning.
http://store.summitracing.com/partde...6&autoview=sku
Old Mar 18, 2007 | 04:12 PM
Dave87IROCZ's Avatar
I put the summit rockers on last winter. Its been a year and I beat the hell out of my car. All is well and I did notice a little more power. I had to get bigger valve covers though.
Old Mar 19, 2007 | 06:31 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Dave, you went from 1.5 to 1.6, with a stock cam, and you could tell a difference?????? what kind of difference???? Better throttle response?????? More power?????? Thanks alot, Tom
Old Mar 19, 2007 | 08:03 PM
BadSS's Avatar
Right. On a TPI car with relatively small hydraulic cam that won't see much if any over 5500 rpm, I promise you'll see very little if any power increase over the 1.6 long slot compared to the 1.6 full roller rockers. I have a set of the 1.6 long slot stamped rockers on my IROC. There's a nice brand new set of 1.6 roller rockers left over from my old speed shop and I would have used those myself it wasn't a waste on a .490 lift cam. You start getting over .500 lift and shifting around 6500,,, the full rollers will free up enough power and the needed extra strength (less flex) can warrent the price difference.
1.5 vs 1.6 on your stock cam and heads might be .1 difference in the quarter mile (about a car length). Some may say they picked up more with the swap,,, but typically they'll do the old hot-rodder's 1/4 turn preload with the swap instead of going back to the full one turn recommended by GM - both the 1.6 rocker and 1/4 turn preload together could be close to if not over .2 seconds. I've set stock cam's lifters to 1/4 turn and the cars typically picked up over .1 seconds and added 200 rpm to the shift point on the old carbed L69s (305 HOs).
Old Mar 23, 2007 | 11:47 PM
moneyman380's Avatar
Car: 1991 Z28
Re: What Roller Rockers to get?
I agree, you get what you pay for with roller rockers.
Also dont buy aluminum rockers, they may be cheaper and lighter but they dont last as long as steel ones.
KO1
16
Oct 15, 2015 05:00 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
92projectcamaro
Sep 29, 2015 07:07 PM
dusterbd
Sep 29, 2015 08:40 AM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
